Twin-turbo Setup?
Twin-turbo Setup?
Hi guys,
new to the forum, I just brought a 92 5-spd SC300 w/ 38K on it. I found a 1JZGTE twin turbo setup that belongs to a toyota soarer. Do you know the TT setup will it fit. I don't understand what's the reason to swap Supra TT's or go for Toyomoto turbo IF you can fit a soarer TT setup into a SC. Please help...thanks
Yes, everythign will bolt in, BUT, electronics will also need to be swapped, so you will need pretty much the entire front clip. And I hope you can read Kanji. Also, don't break anything, because 1jz-gte specific parts arent readily available in the US. This is the LAST course of action I take. The simplest route is turboing the stock 2jz-ge.
The GTE conversion is not difficult if you have the right guidance. I've completed it in my SC300 with spectacular results. I've documented the entire process in a conversion manual, including all electrical modifications, parts list, etc.
Check it out at: www.fly-hawaii.com/lexustt
LunaVyohr
SC- 1st Gen (1992-2000)
01-05-11 11:46 PM
96sc300
Performance & Maintenance
03-06-09 08:17 PM
aussiedave
08-06-05 01:08 AM
