Apex-i S-AFC NEO
#46
I know that it seemed that I was sure about going the SAFC route, but I've been looking into biting the bullet and going straight for the AEM EMS. I figure that I would eventually want to go the EMS route anyway, so why not just do it right the first time, right? One problem I'm having is that the place I'm getting it from wants to know what I need with it. They asked me the following: With the AEM EMS I need to know if you want the 3.5/5 bar map sensor, the HKS DLI, the Intake Air Temp Sensor, or a wideband with it. Which parts do I need? All, none, or some. Help!
#47
I think that all I need is the AEM EMS unit itself along with the map sensor and the intake air temp. sensor (for MAF to speed density conversion). From what I've read the HKS DLI is optional, but would most likely be helpful. As for the wideband, the dyno has one for tuning purposes so I don't think that's necessary. Any thoughts? Let me know...
#49
#50
Thanks guys. I'm gonna get the AEM EMS along with the 3.5 bar map sensor and the intake air temperature sensor. I can't wait to get this all installed! With this setup I shouldn't have any problems with my blow off valve (HKS SSQV) venting to the atmosphere, huh?
#51
Nope, and it'll make more power...if the person really knows how to tune.
#52
Great! Everything should work out fine then because this shop has tuned some very powerful supras as well as other cars with impressive numbers. Let's just hope that the specific tuner that works on my car is as knowledgable as TTSC3. I'll keep you guys posted on what happens...
#53
SAFC's can cause timing advance WITHOUT you even knowing it. If you use bigger injectors w/SAFC, you will be pulling airflow out. Airflow tables in the stock ecu are setup so that when you pull airflow out, you're actually ADVANCING the timing. Now that's not to say I'm anti-SAFC. Not at all. I've made over 600whp with one, and it was totally reliable, but there are still certain things to look out for.
And a wideband is critical when tuning an AEM; otherwise, whats the point? And a Ignition box is very important for higher boost levels; if this guy is staying stock CR, then he wont need one; but much past 14-15psi then the stock ignition system will begin to have trouble.
#54
I have the AEM EMS now along with the intake air temperature sensor and the 3.5 bar map sensor.
Bean: Why is it that you feel there is no point to the EMS without the use of a wideband? Isn't the functionality of the wideband built into some dyno machines? That's what I've been told, but if you have other ideas about the situation then let me know. I'm curious about what you mean by:
And as far as the ignition goes I'm keeping the boost low so I don't think I need that yet.
#55
Exactly. You cant be sure. At higher power levels a wideband becomes something you really need IMO.
#56
So you're saying it's something you need to monitor while off the dyno as well, so just having that feature built into the dyno while tuning will be insufficient? Please excuse my lack of knowledge on the subject. Let ke know. Thanks.
slwazdsm
Performance & Maintenance
04-30-04 08:18 PM
