starting problem
Old 05-08-07, 07:41 PM
93SC300.
93SC300.'s Avatar
Default starting problem
well im having a starting problem on my car. im sure it might be the starter or a bad connection from one of the wires. Usually the car cranks right ove but now sometimes i turn the key and it just clicks. All the lights turn on and all but no crank. The i can try again and it might do the same thing or it might just start. Rarely it cranks a litle then stops. But it kicks over most of the time. Can this be a loose connection or is it time for a new starter?
Old 05-08-07, 08:49 PM
amorphous
amorphous's Avatar
having the same problem myself i'm pretty sure it is the starter just going bad mine been doing it since january still kicking it though i found that if i turn the key really quickly into the on position it will just crank and not click. every car is different and you'll get a thousand possible answers but if you want a sure answer you got to go to the dealer or some mechanic shop
Old 05-08-07, 09:17 PM
SC400DAVE
SC400DAVE's Avatar
It's your starter.
midwest2
25
12-25-12 01:39 PM
Neil4Speed
SC- 1st Gen (1992-2000)
07-04-11 03:58 PM
LuxOut003
10-29-08 05:36 PM
hlb
09-27-06 08:09 PM
Ice350
14
12-07-05 11:55 PM
Quick Reply: starting problem
