2JZGTE 5 speed with twins owners
What rpm do you guys hit full boost at? I think im hitting full boost at around 6000 rpm, is that correct? 2nd turbo transition starts at 4800-5000 and 2nd is fully starting at 5000-5500.
that sounds correct, i think the 2nd twin starts around 4 grand and fool spool around 5-6 i can't remember it's been a while, i ditched the sequential and went to true twins on the 2jz-gte and r-154 i have on the 89 supra
I think I just need to learn the twins some more, I might not have been hitting boost properly because I was only downshifting to 4th. Havent tried from a stop or 2nd yet. I think since I have a 4.27 auto rear, im flying thru gears too quickly to stay in a good powerband.
Yeah, Phil's right about that. I took a look my Dynopack dyno print out of my (pre-single) twins. I was at ~14psi by 3300 rpm and that pretty much held from there on the conservative tune I had at the time. If I set it for 18psi (I never did because of fuel issues), it looks like it would have happened by about 4800rpm. Should mention that full boost and max w.h.p. occur differently.
I found out later that I had a defective Greddy EBC unit
it would not hold peak boost.
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
Chicago Lexus Club Moderator
Wow, im defintely not hitting full boost at 4000. But, I dont think I was testing the twins out properly, I was thinking I should hit max boost when I floor it in 4th or 5th gear, but of course I was wrong.
Having a 4.27 rear end doesnt help either. I gotta install my 6 speed and 3.13 rear end ASAP.
I've taken it from a stop and hit my max psi quickly, so I guess I have to learn. Right now I have seafoam in the tank, so as soon as this tank is gone, back to testing. I'll keep you guys updated, thanks.
The Blitz EBC seems to be a better choice and I'm happy with it. If anyone needs a perfect Greddy EBC head unit (w/o solenoid) I've got one cheap.
What specific boost level do you get and when does it show up?? My max hp numbers occured well after boost showed up.
TurboLexra
SC- 1st Gen (1992-2000)
19
08-22-11 08:17 AM
