Cooling fan romoval
Old 05-14-07, 07:32 AM
Jinx2006
Jinx2006's Avatar
Default Cooling fan romoval
I would like to get the dual electric fans (from Summit probably) for my car, but how do you go about removing the stock cooling fan? Is this mod worth the effort? I heard you gain 10-20hp
Old 05-14-07, 12:10 PM
fwynn
fwynn's Avatar
take off the radiator with the original fan..
then u can take the fan off and do w/e u want
Old 05-14-07, 01:26 PM
Jinx2006
Jinx2006's Avatar
I'm talking about the large white fan that is in front of the motor. Has a large black shroud on it and it it belt driven by the otor. The ones I want are electric. But how do you remove the white large fan?
Old 05-14-07, 01:40 PM
fwynn
fwynn's Avatar
yea thats what im talking about..
just take off your radiator.. sicne ur fan is connected to the radiator..
then when ur radiator is off.. u take ur fan off..
if that makes sense?
BUT if ur just talking about taking the FAN off the black shroud.. good luck on that one.. i dont think it should be hard.. but ive never tried it..
Old 05-14-07, 02:32 PM
comoSC
comoSC's Avatar
I've changed out my radiator and I don't remember the fan coming off with the shroud. I'm pretty sure he's talking about the fan attached to the water pump.
Old 05-14-07, 03:13 PM
Jinx2006
Jinx2006's Avatar
Sorry I don't have a pic, but looking under the hood, you have your core support, then your radiator, then a large black shroud that covers a 1 1/2 foot wide fan that spins when the car is running. It is attached to the motor itself. It is in front of all the pulleys, in between the radiator. What I'm talking about is you can purchase DUAL electric fans like Flex-a-lite to replace this huge fan and gain some horsepower from the pulleys not needing to turn said fan, which I can't figure out how to remove....Sorry for not having a pic.
Old 05-14-07, 03:42 PM
fwynn
fwynn's Avatar
when i replaced my radiator.. my fan came off with it.. so
i dunno now i guess..
maybe its a SC4 thing?
Old 05-14-07, 08:25 PM
JJG2005
JJG2005's Avatar
Yeah the sc3 fan is attached with 4 nuts to the water pump... the shroud comes off with the radiatior, but the fan must be removed separately. Its possible to remove the shroud without removing the radiator, but it would be much easier to remove the radiator, and then you can do a coolant flush while you're there.
I'm installing a single 12" electronic fan now to replace the stock fan. The amount of air it gives off is far more than the stock fan, so a dual fan would work excellent...
Old 05-15-07, 08:12 AM
SCoupe
SCoupe's Avatar
In the real world I doubt you'd see those numbers.
Old 05-15-07, 02:07 PM
underpsi
underpsi's Avatar
there is no need to remove either the radiator or the fan shroud to remove the fan. There is 4 nuts you take off and thats it, removing the fan shroud will make it easier.
Old 05-15-07, 02:10 PM
mkorsu
Zombie Slayer
mkorsu's Avatar
Expect to gain 0 to 0.0 hp.
Old 05-16-07, 08:33 AM
Devir
Devir's Avatar
It's not a HP thing. Removing the factory fan and installing dual electric frees up a lot of space and weight to put in a turbo or other junk.
In my 400, the fan is hydrolic and takes up quite a bit of room.
Old 05-16-07, 12:16 PM
mkorsu
Zombie Slayer
mkorsu's Avatar
uh......I'm quite aware of that...........hence my post
Old 05-16-07, 12:38 PM
Devir
Devir's Avatar
Oops. It makes sense now. I was clarifying "just in case"
Old 05-17-07, 11:29 AM
Sc dRifta
*****Do not buy from this member until further notice *****
Sc dRifta's Avatar
.... i hate it when people give out wrong advice gonna cost u to mess ur car up u dont have to remove ur radiator.......
its 4 i think 10 or 12mm nuts that hold the fan to the pully.
first remove the radiator shroud
then get ur hand in there and rempove the 4 nuts that is hold the fan to the pully
your done
go to pepboys get a electric fan relay kit comes with the wiring harness and relays and everything pre wired for any 12 volt electrical fan
any more help just ask me
btw its more of a 5 hp gain i dyno'd
Quick Reply: Cooling fan romoval
