power steering relocation for aftermarket manifolds on sc300
ok fellas im putting in a aftermarket manifold in my sc300, and obviously the resoivor (sp*) is in my way, so after a bit of research i found what we would need to do in order to move the tank out of our ways.
first we need a tt supra nipple (suction port nipple) to bolt to the power steering pump making it possible to re-route the line.
here is the link to what the part looks like. right side, "suction port nipple"
http://www.mkiv.com/manual/manualtt/...ebuild3538.JPG
from there you will need to tap and drill as described in this thread on club na-t post #14 starts where you would want to follow to complete the job.
http://www.clubna-t.com/forums/showt...ing+relocation
hope this helps some of you. credit goes to ninety five na on club na-t and the search button for making it easy on me to get this figured out.
i will have pics of how it turned out on my sc300 soon. thanks !
here is a pic of the top of the power steering pump minus the resoivor where the suction nipple would go, jst for reference.
![](http://i41.photobucket.com/albums/e272/ben998r/P1000234.jpg)
Reviving an old thread. The links to club na-t do not work any longer.
I'm going to relocate my power steering reservoir for the FFIM, and I have an SC400 reservoir, and I have the suction port nipple.
My question is - what needs to be drilled and tapped? It looks like the factory SC300 reservoir is held on with a bolt, and you would just use that same bolt to secure the suction port piece. Is that not correct?
