Custom SC400 Exhaust on a Budget-- Pics--
Sorry-- It rained so much today my new exhaust was definitely dragging under water as I was trying to get home--
Seriously-- NW Arkansas had a flash flood today-- it was insane-- Tomorrow should be clear and I'll post some video--
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
The Videos--
At the muffler--
![](http://i69.photobucket.com/albums/i80/matt-hipple81/th_Atthemuffler.jpg)
In Town-- Low Speed--
![](http://i69.photobucket.com/albums/i80/matt-hipple81/th_Intowncruise.jpg)
On The Interstate-- With no Drone!!
![](http://i69.photobucket.com/albums/i80/matt-hipple81/th_InterstateCruise.jpg)
BONUS VIDEO! Some Guy Carrying a Lawnmower in the back of a Pontiac G6-- Only in Arkansas!!
![](http://i69.photobucket.com/albums/i80/matt-hipple81/th_LawnmowerinTrunk.jpg)
The Tips after install -- Looks good--
![](http://i69.photobucket.com/albums/i80/matt-hipple81/tips.gif)
![](http://i69.photobucket.com/albums/i80/matt-hipple81/rearknxn.gif)
![](http://i69.photobucket.com/albums/i80/matt-hipple81/knxn.gif)
![](http://i69.photobucket.com/albums/i80/matt-hipple81/frontknxn.gif)
The Center section one more time--
![](http://i69.photobucket.com/albums/i80/matt-hipple81/S5300322.gif)
The pipe I built the center section with--
At the muffler--
![](http://i69.photobucket.com/albums/i80/matt-hipple81/S5300320.gif)
I calculated the 3" to be equivalent to a pair of 2" pipes in volume--
The stockers are 2" -- So the flow should be close to aftermarket--
There may be another 5hp to gain though-- who knows--
I already have my eye on some cheap straight thru's from Autozone-- as long as you can see through them they should work-- I'll step up to 2.25" for those and try to use the factory tips if possible --
The sound may even get better--
My CEL came on the other day along with the TRAC-OFF light as I pulled the trac fuse-- The trac light stays on all the time on the tach but who cares-- The trac-off light however is a new one-- It came on at the same time with the CEL -- I may get the codes read at the parts house tomorrow, but I doubt there's any real problem-- I'm guessing pulling the trac fuse is throwing a code--
I may try resetting the ecu to make it go away-- It wasn't from the exhaust install for sure though--
Don't wanna do that-- You need a balance pipe (x or H-- x is better though) --
I believe you get a similar result with the center section like mine though--
noooooooooooooooooooo
on those mufflers NOooooo
the tip is TOO small (Length).. and having it cut like that is TOTAL rice![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
try to find something like this ;]
![](http://blog.willvs.chu.jp/images/muffler201.jpg)
![](http://www.modacar.com/Merchant2/graphics/00000002/apexi_n1_expert_ti.jpg)
:] you wont regret it ;] cause ive seen many CIVICS with THOSE mufflers u have up there.. not a nice look if i may say
GL
GL
