View Poll Results: Which swap is easier to do yourself into a 1997 SC300 1JZGTE or 2JZGTE???
1JZGTE
13
68.42%
2JZGTE
31.58%
Voters: 19. You may not vote on this poll
1997 SC300 5 speed 1JZGTE swap
Hi, I have searched for days now and have not found the answer im looking for.
1. Has anyone here done a 1JZ in to a 1997+ SC???
2. Is the wiring all that diffrent from the regular 1jZ swap into a OBD1 system?? (Just extending the body plugs)
3 And the last question. Is it easier to do a 1JZGTE or a 2JZGTE into a 1997 SC300????
Chicago Lexus Club Moderator
LOL. So 1JZ is winning? Given a choice without looking at the expense aspect, 2JZ is hands down a better choice.
I know one person. He wishes he just turned his stock motor like many others.
The wiring harness and ECU are different. Also you will need to extend the harness because JDM ECU sits on the other side of the cabin.
It is easier to swap a 2JZ and you'll be making more power.
I think most people don't know what they're talking about.
2. Is the wiring all that different from the regular 1jZ swap into a OBD1 system?? (Just extending the body plugs)
Do you mean the 1jz plugs right up??? so did you get your 97" to run and no lights are on like check engine or anything??? what wires are diffrent can you help?? or direct me where you found how to do it?
1UZFE/2JZGTE
I'm not familiar with the OBDII stuff but honestly I would go for the 2jzgte from the beginning. I went 1J because it was cheap at the time and I just went single because I roasted my stock twins with all that I could have gone BPU 2JZGTE and have about the same that I have now single. Bottom line is you spend some now and some later with the 1J or you spend all now and go 2J. The 2J twins will last for a while can go up to 4XXHP.
my car was a sc400 ,some wires are different on the 300 ,the bad thing about the obd2 is that the bodyplugs wires are all the same colors ,the thing that helped me was i did the swap to my old sc400 and followed what i did with that car
