2JZGTE (maybe 1jzgte too?) - Tach Fix! For newer model SCs 97+
Some of you may have experienced what I call:
![](http://i88.photobucket.com/albums/k200/sean_j_2006/1997Tach.jpg)
That is what the back of the 97+ SC300 gauge cluster looks like. And with that said, you can't do the easy resistor trick.
First I tried the basic ideas that people had used previously:
Tach Output (A16 - Black w/White) of the 2JZGTE ECU straight -- FAILED
Tach Adapter on the Tach Output of the 2JZGTE ECU -- FAILED
Igniter Tach Output (A1 - Black) -- FAILED
Tach Adapter on the Igniter Tach Output -- SUCCESS!!
So with that said, I haven't actually driven the car around with it...but I see a 1k idle and movement when I blip the throttle. For those of you still stuck, this appears to be the answer.
Sean
Sean
![](http://www.jazzproparts.com/photos/8920-2T.jpg)
It is essentially a little box that takes one type of tach signal input and converts it into another type of tach signal which can be "understood" by your factory tach.
I do not have pictures at the moment, but I ran the wire from the igniter, along the firewall and down under the passenger side floor into a grommet. It may not be the ideal path, but it works. And the MSD tach adapter is tucked up underneath the factory ECU kick guard.
I do not remember what I used for the 12V+ and Ground, but you should be able to figure that out.
Sean
no need for a tach adapter .the resistor is there ,you just have to take it apart to get to it,ive done it to mines
https://www.clublexus.com/forums/sho...d.php?t=293547
being auto or manual will not cause the tach not to work .but if you did not bypass this resistor the tach will never work .i never did a 2jzgte swap but the only thing that will cause it not to work other than the resistor is a wire being in the wrong place
tuninghaus
Performance & Maintenance
05-28-19 06:01 PM
vntperform
28
01-29-13 07:46 PM
