CEL Help.
Old 06-05-07, 06:11 PM
97-SC300
97-SC300's Avatar
Default CEL Help.
ok today when i started my car after only about one minute of running it threw a CEL, i went to work and it came up as P0116 Engine Coolant Temperature Range/Performance problem. and after looking over at the possible problems i think it may be a bad Coolant temp sensor. anyone ever hear of this kind of problem before on their SC? would anyone have anyother clues as to what it may be? i was thinking thermostat but it would not throw a code at the first minute of running. any help would be great.
Old 06-05-07, 06:52 PM
audi2nr
audi2nr's Avatar
i'd go after the temp sensor first, i know on audi's espically older ones, they will throw that code if the t-stat sticks open, the ecm is retarded and thinks the temp sensor is not working properly because the engine does not heat up all the way because of the stuck t stat. i've been bit by that mistake before. an easy to make sure is to warm up the engine and using an external thermometer sure the rad hoses get to operating temp. i think its like 180 ish?
ALLANC
23
08-23-15 03:43 PM
MYTOYLEX
07-08-13 02:26 AM
Lexus082
09-05-12 10:16 PM
ksoazn
11-04-06 03:44 PM
soarer479
10-11-05 07:36 PM
Quick Reply: CEL Help.
