help please read!! 1jz swap!!
here is the link for the ecm pinout, get an electrical wiring digram for your sc, and match up the wires the ones you need to hookup are the last 2 sections of wires listed on the link, the first 2 sections are between the engine and the ecm, which are already hooked up.
http://www.trackdaymedia.com/~manny/...0__pinouts.pdf
you dont need to replace the harness if you can do electrical. a new harness is hard to come by, espically a soarer harness.
thanks
-stan
ok, heres my question. electrical is not a problem for me. but where do i get the body plugs from a chaser from? mk3? what about a/c? i want my a/c to run too. the stock sc harness have 3 extra plugs, do i tap those wires if the mk3 body plugs work? if everything i said b4 is correct. do you happened to have the pin outs for the obd1 sc300 body harness? now get to the oil pan question. does the 2jz-ge oil sump work for the 1jz?
thanks
-stan
thanks
-stan
yes the sumps are interchangable.
