help please read!! 1jz swap!!
well i just bought a 1jz from suns auto here in houston. this engine looks fine and all, but heres a problem im dealing with. the guy that runs the shop doesnt know if the engine is from a supra or a soarer and the motor was dirt cheap, good compression and no plays with the turbos, so i coudlnt miss this deal. the clips to the ECU on the 1jz is gray, and the plugs looks like a triangles. it looks nothing like the one i have on my sc300, could it be a soarer harness or a supra harness? my other question is the motor came with the auto tranny. the ecu is A/T would that cause a problem? i have a W58. would the w58 bolt up to the 1jz? and about the flywheel and the clutch can i use the 2jz flywheel and clutch for the 1jz?
thanks for the help
-stan
thanks for the help
-stan
those questions have been answered before.
use the 2j flywheel and buy an sc300 clutch kit and the w58 bolts on. the a/t ecu works as well. so are you saying you might have a soarer harness and a supra ecu? or do the plugs don't fit into the ecu? everything should plug in.
If the ecu plugs on the harness have 2 rows of pins going across its not a soarer harness and likely a supra harness...
example of one connector
If the ecu plugs on the harness have 4 rows of pins going across its a soarer harness![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
example:
i tried... hope you get what i meant by that...
also-
supra= front sump oil pan, hydrofan set-up
soarer= rear sump oil pan, regular clutch type fan
example:
also-
example:
also-
example:
also-
