Pulling as much Power out of the 1UZ-FE as possible
#46
#47
Thank you all for the Insight, im currently talking to a buddy of mine that owns the shop i got dyno'd at, he said yes its a dynojet
we are also working (planning stages) of a rear mount turbo kit. Mostly just dreaming for now working up a parts and cost list, Any clues? any body finished one? i will purchase a write up if some one would be willing to make one =)
ALSO nitrous info, is there a site or link some one could give me to read up on Nitrous? do's and dont's that kind of things
#49
I thought Emerald's turbo was in the cubby where the spare tire is normally in a stock car. I would be stunned if she mounted it before the cats. Where would it go and still be protected? I think her turbo is very close to the mufflers in fact: long pipe to the turbo, long pipe to the intercooler, short pipe out to the mufflers.
#50
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
#52
Fitting a turbo anywhere under the SC will not be easy at all...put the car up on a lift, and look under it for space for any decent sized turbo to be fit anywhere under the car...Very tough...On top of that, you probably have your car already lowered, or will lower it...I would like to see it done, but it will definitely require modificstions to fit. There is no room in front of or behind the front cats...Go look at the space...You would have to heavily modify the floor board and tunnel to fit there. Perhaps there is room at the rear where the mufflers are, but I am not sure, and the piping would be a nightmare. You could remove the spare tire receptacle, and place the turbos there, but what work...Maybe it will work for ya, but good luck...
Ryan
Ryan
#59
hey guys, im thinking of nossing my 95 sc400. Im such a noob at performance stuff which leads to my next noob question. ok so i want a zex 100 shot system. do i get wet or dry nos? i dont even know the diff. thats how nub i am. What else will i need? how much will everything run me? and does anyone know a shop in so.cal that can install? i guess i made the car look fast but its no where near as fast as it looks! any input will be greatly appreciated. thx
#60
A "dry system" only injects nitrous only
A "wet system" injects nitrous and fuel at the same time.
I would get the wet system because you will not have to compensate for fuel when the nitrous is injected. A wet system is a safer bet. Installing a kit is fairly easy. Just make sure you price around. A complete kit should take no longer then 4 or 5 hours to install if its a reputable shop with experience.
good luck
chris w
