1JZ-GTE gasket kits
Hey, my 91 soarer TT requires a reseal job and I know a few members here have converted their sc300 's to a 1JZ
. I need a gasket kit or just the seals I need to get the job done. Is there anywhere in North America where I can get my hands on a gasket kit/seals for a 1JZ engine??
Ben
Ben
Welcome...Lets move this over here to the engine forum...Then read this...it will save you tons of time and hassles in the future.![Big Grin](https://www.clublexus.com/forums/images/smilies/biggrin.gif)
https://www.clublexus.com/forums/sho...d.php?t=266465
As far as I know the head gasket is interchangeable and I think the valve gasket can be modified to fit the 1JZ. But I need a reseal job, the valve cover is leaking and the sub oil pan is leaking. There are a few seals to work with to get that far down the engine bay . . . I don't want to struggle in modifying 2JZ parts or finding other seals that may work when there should be a gasket kit out there for the job . . .
Toyota has everything you need. I got mine resealed @ Manhattan Beach Toyota. They did a great job and I would recomend them if you are in the South Bay. SoCali.
http://www.supraforums.com/forum/sho...d.php?t=319081
Call Jeff At Champion Toyota. $138 isn't bad for the entire gasket set including valve stem seals...
FuMoFFuTT
Performance & Maintenance
03-13-09 07:30 AM
