help, neutral safety bypass , no crank
hey guys, after soarer clip installed with r154, no crank . ck starter is ok, battery is good to starter. beside running wire to" nws and sta "on ecu to switch by the clutch pedal. is there any thing else. i shorted out nws to sta , still no crank. must be a positive or negative pull down relay. threads i found from kaiser referred to a 2 rolls ecu, my soarer ecu is 4 rolls on each plug. also, it is a manual harness with auto ecu. jump on it guys.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
yeah!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
she start, idle right nice, no smoking. no one on this forum response to this issue. thus i download a online lexus sc300 wiring diagram. will post simplify version of 'neutral safety switch', check engine issue, temp fix deal, anti-theft starter issue.also trying to figure this airbag light, most likely wiring. thanks to armyastro for support. sometime swap is a pain in the ***. easy diagrams to come.
Japji316
Performance & Maintenance
11-25-15 11:19 PM
