The start of some V8 madness
Old 05-30-08, 10:49 AM
  #271
craaaazzy
craaaazzy's Avatar
ahhh, so there is a bolt. got it. have to make sure i have a 24mm socket then. thanks blizzy!
Old 05-31-08, 07:22 AM
  #272
Kbdread
Kbdread's Avatar
Thanks for the info Blizzy, another question if i may... If i have the option of getting a 6-speed V160 should i take it? I asked scott about his conversion, i know it's a bit more costly, but he hinted that you might know of a reasonable clutch setup and the same adapter will work. Any advice for me on that?
Old 05-31-08, 02:47 PM
  #273
ScottURnot
ScottURnot's Avatar
Location: Sideways on the Yellow Brick Road! < Thats KS!
FYI, There is a good deal in the SC classifieds on a adaptor.
Mark, sounds like super progress. I can't wait for you to get it running.
Old 05-31-08, 06:59 PM
  #274
atekt
atekt's Avatar
Sounds like the progress is coming along well! Cant wait to see it up and running!
Old 06-06-08, 07:46 PM
  #275
KC95SC400
KC95SC400's Avatar
Stated on 6/4/08
Originally Posted by Blizzy
ps. My clutch line is scheduled to arrive on my door step this afternoon. I am pretty psyched.
?????????....well......?????????
I think he's just trying to keep us in suspense!
KC
Old 06-11-08, 01:51 PM
  #276
Blizzy
Blizzy's Avatar
Guys...
It has been a long time.
Last week, I was bolting up my clutch line to the master cylinder. This was the last wrench work required for the whole swap. My blood pressure was high and the anticipation was killing me. Due to the small size constraints and my lack of focus, I cross-threaded the line and it was leaking pressure.
Fustrated as all hell, I took a week off from the car. This is the first I have been on Club Lexus since. I knew that if I posted that I was teaking a week off, the encouragement of the CL faithful would get me back under the car. I really needed a break.
I got under the car again last night. I used some JB Weld to permanently attach the main clutch hard line to the master cylinder and seal the union. It looks nasty; but, -I filled the system with fluid a minute ago and tired it out- it works like a charm.
I have spent the last 20-30 minutes researching the neutral safety switch bypass. I am going to head to the hardware store to get what I need so that I can be on my way. The car itself is on the ground and ready to rock as soon as I get that 12V run under the driver's side dash to the neutral safety switch wire. I would be disappointed if I was not pulling out of the garage by dinnertime.
I apologize for the delay in getting this beast running. I really just needed to get my mind on something else. I actually put some researching into theorizing a way to break the current water speed record for a man-powered watercraft of 21.7mph by an MIT engineering team. I also got some planning done for next school year.
It feels good enough to have the car on the ground fully assembled and ready to rock. I imainge it will feel much more rewarding to pull away and get used to the new set up while I break in my clutch.
I will definitely have updates on the progress as I debug the system. I imagine there will still be work to be done before I can offically close the book on this 5MT chapter and open the file on the supercharger build up.
I will have videos of the beast as soon as possible. I have a number of pictures I took from a week ago that I still need to upload.
-Mark
Old 06-11-08, 03:11 PM
  #277
97-SC300
97-SC300's Avatar
Glab to hear you are back to the build Blizzy. Have you figured out how to make the speedo work yet?
Old 06-11-08, 03:22 PM
  #278
TheRonTom3
TheRonTom3's Avatar
We are all rooting for you and we all know the frustrations of set backs.
Good luck.
Keep up the Epic WIN
Old 06-12-08, 12:19 PM
  #279
Kbdread
Kbdread's Avatar
Happy to see you back Blizzy, i know how it is ... sometimes you just have to put your mind on something else for a while, it is amazing how things work out after you take that break. Looking forwad to the pics..
Old 06-13-08, 04:49 AM
  #280
RedPhoenix
RedPhoenix's Avatar
And... and... and.....
Old 06-13-08, 08:06 AM
  #281
Blizzy
Blizzy's Avatar
The neutral safety swith override was a success. The car started up on the first crank (as it should have). It was nice to hear eight cylinders after such a long time with only four at my disposal.
The JB Weld on the cross-threaded clutch line/master cylinder sprouted a leak in one spot. I have reinforced that spot as well as the rest of the area where the compound has been laid down. I am hoping that it will stick for me. The cure time of 16 hours comes to a close at 1pm this afternoon.
If the cold weld doesn't hold, I will likely have to break down and get another master cylinder and main clutch line. Fortuntely, there is a yard in western Ohio that has one available. I have them on call for the part, and I may end up heading down to ****** it up this afternoon or Saturday if my spot treatment with the cold weld ends up being a failure.
Fingers are crossed.
ps. I am going to get the pictures from my camera onto the computer here this afternoon so that I can upload them to the forum. HOpefully I can share an initial driving impression when I do.
Old 06-13-08, 11:25 AM
  #282
ihiryu
ihiryu's Avatar
why don't you try working the threads? you might be able to save them
Old 06-13-08, 02:54 PM
  #283
CTS-SC4
CTS-SC4's Avatar
He's right Mark, you could possible get a tap & die set and salvage it with some fresh threads and some teflon tape. The teflon tape does wonders it's saved me a couple of times. Good luck with everything man.
Old 06-13-08, 04:51 PM
  #284
97-SC300
97-SC300's Avatar
what did you do to make the neutral safety ting to work? post some pics if you can.
Old 06-13-08, 05:12 PM
  #285
gdc5ind
gdc5ind's Avatar
https://www.clublexus.com/forums/sho...d.php?t=327356 thats a thread on the neutral safety thing. even tho you already posted in the thread.....
Quick Reply: The start of some V8 madness
