tranny
Old 06-27-07, 02:06 PM
durtysc300
durtysc300's Avatar
Default tranny
so i'm most definately gonna put in a turbo system..but i have concerns about my trans. i would prefer to run with a six speed manual but i dont know what kind of mods i'd have to make for that..something easy, simple, reliable, and relatively inexpensive is what im shootin for
Old 06-27-07, 03:20 PM
skpark70
skpark70's Avatar
Getting a 6 speed will cost you 5-6K new, I'd rather go with boostlogic tranny for less than 2K.
Old 06-27-07, 07:22 PM
Blizzy
Blizzy's Avatar
depends on your power level desires. the W58 manual that comes in the SC300 is good to about 400wtq. The auto in the SC300 is less durable. A six speed costs a ton (~$4k+), but it will most likely be the last tranny you will ever need. Boost Logic's auto rebuild is a good value at ~$2k. But, that rebuild has had its moments.
Old 06-27-07, 09:39 PM
HTQCummins
HTQCummins's Avatar
what do you mean by "has had its moments"? was it just tough to do or couldn't hold the power?
Old 06-28-07, 04:41 AM
Blizzy
Blizzy's Avatar
there are a couple guys on the forum who have has bad luck with them in the way of them failing. but, they have shown to be -largely- extremely reliable.
Old 06-28-07, 07:42 AM
SCoupe
SCoupe's Avatar
If you're going na-t or 2j swap and don't greatly exceed 400 whp/trq you don't require a 6sp.
The six speed swap is anything but easy, simple and especially not inexpensive. They are in demand and there is a limited supply. You could find yourself spending close to $6k or more on this plus you'll need the rear end and that not in that price, (LSD is going to be another $~1 - 1.5k as well. Your going to spend the same on the 6sp as the turbo. So you got wallet?
You need to spend some more time reading posts on this topic, its anything but new and there is a ton of info on your direct question here, clubna-t.com and supraforums.
Halon
SC- 1st Gen (1992-2000)
08-31-10 10:15 PM
nofish
09-25-07 09:28 PM
jibbby
34
02-27-07 03:06 PM
Quick Reply: tranny
