ive searched for like 20 mins, and can not get a def. answer if the supra front mount kit will fit on a sc with no mods(on a 1JZ with stock twins). i dont see why it wouldnt, but before ordering one id like to make sure. thanks. ALSO is the lower radiator hose the same on the 1jz as the 2jz?
The Supra TT FMIC Kit will fit a SC with 1JZ. got_trd from FL and a few other people ran that setup. Yes the lower radiator hoses are the same. Only one you need to change is the top.
I just looked and couldn't find it. If you go this route please post up some pics. I'm curious if the intercooler piping is going to work with no modifications.
i pulled the smic out today. and noticed on the drivers side where it looks like the piping would come through theres ac lines, running a mkiv fmic wouldnt require removing these would it? if anyone had any pictures it would be greatly appreciated. thanks.
I fabricated my own intercooler piping using pictures from mk4s with FMIC's
This is the same route.
It might be the same route, but it's not the same piping. I'm pretty sure the SC300 needs longer piping. Holy zip ties heh. Looks good though! Nice job.
