I got a full service for my car (sc300), all fluids, plugs, wires etc. The car runs great but I think my idle is low. My mechanic says that hey checked everything and says its normal. My idle is on the first marker below 1000rpm or just a little under. He says he hooked it up to a diagnostic and the idle after driving and letting the car run fore 30min is at 650-700. So my question is where is your udle after a fully warmed up car?
1000rpm-----
----- Im here or just below
0RPM-----
P.S. Ive also clean the fuel injection, throttle body and IAC. The car runs great but I dont know if i should be worried. Thanks in advance.
I had this same problem after changing my plugs. Afterwards my idle was at about 500-600 and at times even stalled. All I did was tighten th Idle control valve a bit since the two screws it is mounted on had a bit of room for adjustment. After doing so, I believe allowed the throttle plate to twist open just that little bit more to allow more air into my engine and thus regulate my idle back at 800rpms.
1000rpm-----
0RPM-----
Thats about where healthy motors should be idling. You have nothing to worry about. Just keep taking care of her like you are now and she'll be taking care of you forever.
