new fans! pics
Old 07-16-07 | 07:18 PM
clevercat's Avatar
clevercat
Originally Posted by audi2nr
if i left the fans on all the time my watertemp would drop down too far, it doesn't take long for these fans to pull the watertemp down, i was actually suprised. i do have a fairly large fmic but it doesn't seem to affect cooling performance too much right now
Do you have 1JZ?
I have Flex fan with auto temp control on my Z32TT, which works fine because I have 2 big side intercoolers.
However, this is a common problem for 2JZ-GTEs.
Old 07-16-07 | 10:20 PM
audi2nr's Avatar
audi2nr
Originally Posted by clevercat
Do you have 1JZ?
dunno if u saw the pics or my sig, but yes i am running a 1jz, everything seemed to be working properly on my drive to and from work today which is like 17 miles each way in about 75 degree weather.
Old 07-17-07 | 01:26 AM
turbochris's Avatar
turbochris
Here is a link to the thread i started a while back.........These fans were cheap and are very common and easy to install...
chris w
link
https://www.clublexus.com/forums/sho...d.php?t=288108
Old 07-17-07 | 08:01 AM
clevercat's Avatar
clevercat
That's cool!
I used to sweating my *** off as I sat on traffic in 90 degree.
I felt the warm A/C air as the temp gauge went up pass the half mark.
Love that sauna
Old 07-17-07 | 08:29 AM
sc250tt's Avatar
sc250tt
electric fans are a waste of time on these engines.nothing can cool better than the stock clutch fan .15 mins of hard driving with the ac on and the temp starts raising not to mention the extra voltage your using to run those fans
Old 07-17-07 | 09:40 AM
clevercat's Avatar
clevercat
Actually, there is a fan that puts out about same CFM as OEM without all that rotating mass.
AAP Motorsports Dual Fan Kit with Shroud for 2JZ-GTEs.
It's a bit expensive but it will do it's job.
http://www.mvpmotorsports.com/Templa...201&SearchYN=N
Old 07-17-07 | 11:05 AM
Blizzy's Avatar
Blizzy
Thank you for this link. Interesting information for sure.
Taking a quote from the MVP ad:
"This kit includes 2 of the highest flowing Zirgo fans available. The stock clutch fan produces 3,300 CFM of air. The dual Flex-A-Lite fans produce a low 1,200 CFM. This dual fan kit produces 3,350 to 3,400 CFM! No more worries of overheating by installing an aftermarket kit!"
Old 07-17-07 | 11:24 AM
gadgetSC's Avatar
gadgetSC
Default Electric Fans are Great
I've been using electric fans for some time now. I started out using the Flex-a-Lite fans with no problems keeping cool in 95+ weather.
The AAP fans work great also. I have a set for both of my cars.
gadgetSC
Old 07-17-07 | 11:46 AM
clevercat's Avatar
clevercat
Cool!
I will post my pix with the colling upgrade within few weeks.
Old 07-17-07 | 06:41 PM
audi2nr's Avatar
audi2nr
gadgetSC
see i told u guys the fans worked pretty good!
Old 07-17-07 | 06:51 PM
Blk97SC300's Avatar
Blk97SC300
I have dual electric fans- they flow 2,000 cfm each (4,000 cfm total). I have NEVER had a single problem with the car running too hot or too cool.. and I have a rather large FMIC as well. I drive to and from work/school in 100+ degree heat here in socal. It cleaned up the engine bay quite a bit. I also bought a new alternator (high output, I believe it was 150amps vs the 80-90 amp for the stock alternator). I'll post pics if anyone is wondering what it looks like. They're shrouded too, so it looks pretty good.
I bought them from summit for a little over $200.
Allen
Old 07-17-07 | 06:56 PM
Blk97SC300's Avatar
Blk97SC300
http://store.summitracing.com/partde...0&autoview=sku
These are the fans i'm using. ^^
Rash
01-21-09 08:45 PM
BBriBro
01-12-09 10:05 PM
play123boi
02-19-07 02:26 AM
BlueKush86
13
07-18-06 07:50 PM
