97 SC300 w/USDM 2JZ-GTE and V160 <Speedometer Question?>
Old 07-16-07, 10:17 PM
vntperform
vntperform's Avatar
Default 97 SC300 w/USDM 2JZ-GTE and V160 <Speedometer Question?>
Folks had a question...
A 97 sc3OO with a usdm 2jz-gte w/v160 swap and his speedometer follows the revs from the tach when the car is driven fast/hard. Basically if you rev the car up... the Tachometer goes up but the speedometer follows even though your sitting still....
Any suggestions, or comments on what the issue could be?
Thanks!
Old 07-17-07, 02:37 AM
TheMole
TheMole's Avatar
Was it previously an automatic? Could be wiring issues.
Maybe this thread is of help: https://www.clublexus.com/forums/sho...d.php?t=284613
Old 07-17-07, 02:42 AM
vntperform
vntperform's Avatar
Yes it was an auto prior to the swap... does ^that still apply?
Old 07-17-07, 06:30 AM
sc250tt
sc250tt's Avatar
all you have to do is find your tach wire .i will try to get the pinout for you
Edit: on ik1 bodyplug the wires are on pin 6 and pin 7 ,cheack and see if those are pinned on the gte harness
Old 07-17-07, 09:53 AM
vntperform
vntperform's Avatar
Where is ik1 and what pins should they be?
Forgive me as i'm a newb to the whole swap business, I bought the car with the swap already done and just want to tie up some loose ends.
Old 07-17-07, 10:16 AM
sc250tt
sc250tt's Avatar
this thread has pics of the plug ik1 is right next to ik2
https://www.clublexus.com/forums/sho...d.php?t=236548
Old 07-17-07, 03:56 PM
vntperform
vntperform's Avatar
This will remedy my speedometer issue?
Old 07-27-07, 07:28 PM
vntperform
vntperform's Avatar
Anyone?
My tach is working fine, but my speedo goes buzzerk regardless of what you do...and it was fine before the 2jz-gte and v160 swap. Any ideas, anyone?
Old 07-30-07, 10:11 PM
vntperform
vntperform's Avatar
sc250tt,
you referring to the orange plug?
Old 07-31-07, 06:30 AM
sc250tt
sc250tt's Avatar
Originally Posted by vntperform
sc250tt,
i sent you a pdf ,hopefully it can help
Old 07-31-07, 08:13 AM
vntperform
vntperform's Avatar
Sc250,
I received the pdf file you sent me yesterday, but it DOES NOT tell you where the IK type plugs are or what the details of the plugs are it just gives you the schemetics of wiring. Do you have any other electrical diagrams for the sc? I'm stumbled and frusterated.
All I need is the full electrical diagram that shows the actual plug and what each plug represents.
Old 07-31-07, 07:33 PM
Supra Dr
Moving SC Threads
Supra Dr's Avatar
Val, the IK plugs are above the right kick panel. The 1 link
shows the plug in hand.
Sounds like the tach & speedo are spliced to gether by accident.
Old 07-31-07, 08:45 PM
vntperform
vntperform's Avatar
Supra Dr;
Thank you for responding, finally someone that can help me!
I traced the 2 wires from IK1 one is a solid red on pin 6 and one is a solid blue with red tracer on pin 7 and I traced them all the way up to the gte harness and they are exactly as they should be, connected to the same two wires from the gte harness. Now i'm wondering if there is an issue with the wiring behind the cluster. Would that be where the tach and speedo wires come together?
Well the speedo only goes crazy while driving, if your sitting still and you rev the engine up; the speedo stays at zero. But while driving the speedo needle is bouncing all over the place; at times it reads accurate, but if you hammer it then it goes all outta wack.
Also thanks to sc250tt for the schematic.
Old 08-01-07, 10:47 AM
sc250tt
sc250tt's Avatar
so if it is in the right pins maby your speed sensor is bad .i saw a kid on sf having the same problem with the speed jumping around when driving hard .did you fix the tach?
Old 08-01-07, 12:31 PM
vntperform
vntperform's Avatar
my tach is fine, has always worked properly.
Got a link to his problem?
Quick Reply: 97 SC300 w/USDM 2JZ-GTE and V160 <Speedometer Question?>
