Planning some mods
I can't find the receipt but I think it was like $40 dollars from Lexus.
Luckily for me, both the Toyota dealership I work for and my local Lexus dealer are Hendrick dealerships, so I get an awesome discount on parts.
Here is a site I use to get a reference on how much parts will cost me. I’ve never ordered anything from them but it’s a useful site. Unfortunately they don’t list part numbers though.
http://www.trademotion.com/partlocat...08&catalogid=0
KC
KC
I just updated my thread. I have been amazingly busy with summer grad classes.
Your parts looks awesome. I am not surprised at all that you could get everything done in one day. Most every part you have is a direct bolt on. And, with a lift, dropping the tranny with be very easy.
Good luck man. I will be anxious to see your reaction to the mods.
-Mark
So this isn’t really an update, I’m still waiting for the headers, but I changed my ignition coils and thought I’d share.
Problem I was having – Low speed cruising (25-30mph), very light throttle, my car was missing a little. Problem a little worse when raining or humid. I had already replaced the caps, rotors, wires and plugs. I tested my ignition coils and resistance was high on the secondary circuit. Spec is no more than .6 ohms, I had .9 ohms on one coil and 1 ohm on the other. It doesn’t sound like allot, but .9 ohms is 50% higher than .6 ohms.
Anyway, changed the coils and the miss is, so far, gone. That was the result I hoped for.
As a bonus, there seems to be less of that famous 1uzfe hesitation off the line. Still a pig, but less so.
Also, there is a ground wire, not sure for what exactly, that attaches to the driver side coil bracket. I cleaned the connection point and installed a new 10mm bolt. To my surprise, I now have less light dimming.
I also ordered 2003 ES300 washer nozzles, but they only sent me one, so I haven’t installed them yet.
I am now seriously considering putting an LSD in my car, thanks to Blizzy. Check out the thread in his sig if you haven’t already seen it.
Thanks for reading,
KC
Thanks for reading,
KC
LexBrett
12-10-14 04:45 AM
rwdanthony
Performance & Maintenance
14
12-22-08 01:51 PM
Hollywood
Performance
08-15-05 02:53 PM
