need help plz urgent (Car dying)
thanks in advance for reading and trying to help!! this is my situation
yesterday i boost my car i drove it out off my garage let it worked for 10 min and while going up the flatbed towing, the car stalled, i did not turn off the key and wen the guy put on the booster the car started by itself, so i took off the booster pack then turn off the key, went back put the bosster back on, and wen i started the car it runs for 2 or 3 sec then shuts off!!!!! tryed 5 times and stopped trying!! can anyone help or has advise???
thanks again for trying to help
sam
sam
i was trying to explain what hapened before it starting doing this
^^ yeah probably batt charger, but it sounds like dead alt/alt fuse?
try to charge/boost it for longer period of time and see if it will stay running longer, if so then it's def an alt gone south
plus if it was the alt wouldnt the battery light come on???
i had alt go out twice on me, first time batt light came on second time it didn't ![Dunno](https://www.clublexus.com/forums/images/smilies/13879dunno.gif)
you might have something else going on, were you doing any repairs or anything recently?
why was it on the 'booster' in the first place? and why is it getting towed. Give us more information and we can better assist you.
the reason why it was on the boos is battery was dead, the car has not moved for a while because the rear subframed broke, and i was towing it to lexus
I suppose you could try putting a new battery in and seeing if that worked. I'd take the alternator back off and have it checked at an Advance Auto Parts.
My car had a problem with the nut on the power wire backing itself out and I'd lose charge, so I locktite'd it with two nuts and haven't had a problem since. And I put a brand new battery in as well.
but one thing still wories me, the first time it stolled i went to put the booster pack on the batery and the car started by itself as soon as the bosster pack was on the batery pole what could do that??????
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
i have a feeling you're not telling something
you got something going on with electrical system
LexFather
08-26-07 09:35 AM
