Z32TT Vs. 2JZ-GTE SC
I just completed the Turbo upgrade of my beloved Z32TT.
I was reading the dyno result of my Z32 and decided to compare Z32 Vs. 2JZ-GTE SC.
They are totally different animals.
Z32 is more nimble and runs like a cheetah yet SC runs like a Bull.
SC is about 100 lbs heavier than Z32.
Z32 has VG30DETT, V6 with Bi-turbo set up (5 speed)
SC has 2JZ-GTE, Straight 6 with sequential turbo set up (6 speed)
Both cars are boosting about 18 PSI with stock internals.
In a way, this is an unfair comparison because Z32 is highly modified running aftermarket turbos, etc but boosting low and SC is running is a basic Supra TT with 6 speed and stock turbos boosting high.
![](http://i121.photobucket.com/albums/o207/clevercat/My%20Z%20Pix/Z32Dyno21.jpg)
![](http://i121.photobucket.com/albums/o207/clevercat/My%20Z%20Pix/Z32Dyno11.jpg)
Z32TT (Dyno2)
386 WHP @ 6180 RPM
347 TQ @ 4850 RPM
![](https://i121.photobucket.com/albums/o207/clevercat/SC/SCDyno2.jpg)
![](https://i121.photobucket.com/albums/o207/clevercat/SC/SCDyno1.jpg)
SC300 (Dyno2)
322.8 WHP @ 5737 RPM
340.9 TQ @ 4270 RPM
As the big boy boosting around 4K, SC pulls like there is no tomorrow.
I feel like SC pulls faster and harder than Z32.
However, speedo tells a different story.
I am going much faster in my Z than SC.
I have not had a chance to run them side by side so I do not know which one can out accelerate the other from 60 punch.
I think SC will jump on Z32 and able to keep up with Z32 from 60+ punch.
What do you think?
Z32TT (Dyno2)
386 WHP @ 6180 RPM
347 TQ @ 4850 RPM
SC300 (Dyno2)
340.9 TQ @ 4270 RPM
What do you think?
How is the SC 1k lbs heavier than the Z? My sc300 weighs 3,400 lbs.. it's not really heavy by any means.
Interesting comparison though.. A Z with a turbo upgrade barely makes more power than a 2JZ with stock turbos.![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Allen
Allen
I thought SC is about 3700?
Z is about 3600.
Stock Z32 TT makes about 280 WHP on Dyno.
100 WHP+ a lot...
Then again, I can single turbo my 2JZ-GTE and make a butt load of HP.
Z is about 3600.
100 WHP+ a lot...
I think you meant 100 lbs
Well, I weighed my sc300 myself (at a recycling center scale
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
GTE has stock TTs boosting MAX @ 18 psi.
I heard some people running higher boost but 18 psi is high # for the stock twins.
My Z32 is capable of boosting up to 25 PSI (500+ WHP).
However, I have limited to to 18 PSI so I can keep my stock engine for a while.
If you are interested, here is the catch!
SC is has less HP & about same TQ as Z32.
However, SC is 6 speed, HP & TQ comes in earlier than Z32 and supposedly weights less?? (per Blk97SC300).
If you are a motor head, you will find it very intresting.
What is your opinion?
It's like Cheetah put herself into overdrive catching up with the dinner.
In other hands, SC runs like a bull.
It put you back in to the seat moment you floor it and don't let go until you let it off. The front end raises up and it's really loud.
I feel like I am in Cessna 310 taking off from runway.
Yeah, it's not really a good comparison based on the lb/min of airflow on each setup. Get the same turbo setup/same mods on a TT SC, then you can see the different dynamics of each CAR, not engine. Gearing, weight, will all play into how the comparison plays out, but you can get a simple comparison for the car itself, not really the engines.
