2JZGE with ITBs?
Has anyone run ITBs on the 2jzge? If so what size TBs did you use? Was it a custom mounting or is there a kit(I have never seen or been able to find one)?
These cars are far too heavy and large for a "lack of torque" motor. You will never ever have the amount of torque that a nice bruit turbo motor could put out in a full out N/A build.
Higher compression, headwork, lightweight internals that are needed for a high horse power N/A is just not financially the smartest way with these large discplacement 6 cylinders. If you want N/A, go with a V8.
I'm sure it sounds cool and may rev to the moon, but your car wont be going anywhere quickly.
who says that the ITB's are for an N/A application only. I used to run ITB's in a plenum on my boosted honda. It was good for another 23 whp and made the motor much more responsive since each individual cylendar was getting almost the exact same amount of air and not starving any one cyl. I mean if its good enough for an RB26DET or Avenir SR20det then why not a supra.... just some things to think about....
The thread starter asked primarily about the GE motor, not the GTE.
On the basis of solely making power and torque, a large diameter throttle body with a well shaped intake plenum designed around intake port length and width and valve diameter can make just as much as any ITB set up on any naturally aspirated or turbo application and vice versa.
Some people like the complexity and sound, some people like the easy just as effective way. Boils down to personal likings really.
Bingo. ITBs on a honda are ok because Honda heads flow RIDICULOUS CFMs. So do some nissan motors.
Not JZ motors
While they can make a ton of power, the heads dont flow that well considering the weight of the engine/car, etc.
It'd be much more cost effective to get a cheap turbokit and run like 7psi on stock fuel.
Not JZ motors
My whole thing is I don't want to be like everyone else and go turbo just because its the easy way to make my car fast. This is my daily driver right now and I am not looking for ridiculous amounts of power or torque, just something fun to drive that sounds and looks good at the same time. Fuel efficiency is a concern and I have heard other places that ITBs can be tuned to get better gas mileage that just about any other intake system. Besides, who doesn't love the sound of ITBs???
Thank you for all the replies. They opened my eyes to a few different things.
there was someone on SupraForums who did this on their GE and tuned it to 270+/- whp. It sounded awesome, but the amount of money and R&D that went into it, i'm sure, was astronomical.
M3's are much more of a performance car from the ground up than the Lexus SC chassis was ever supposed to be.
Yes you can make a great N/A high power build from the GE with enough money (key word there), but i'm sure you will find yourself bored soon thereafter and looking for more power. Turbocharging in general has so many more varieties of power and expandability and flexability its just the more cost effective way to make power.
And to those that have never tinkered with tuning an N/A ITB'd high compression motor, you might not understand until you actually get to build some from the ground up and get them running properly. Weather affects ITB's greatly. Unlike their finicky carbeurated counterparts that tend to be moreso, atmosphere (the enviroment from which the air is being sucked into the motor) greatly affects the motors power potential through the seasons.
Turbocharging is a little more simple to deal with since you have a compressor to simply, at high speeds, compress the air into the combustion chambers.
This is not to bash any of your dreams or wishes. But to just give you something to think about since you are still wanting to use this car as a daily driver that has good fuel economy and minimal maintenence.
No matter what way you do it, making more power takes more fuel, takes more air, and takes more money, increases overall heat in the power and its working parts, and decreases the life of the motor.
-Jonathan
-Jonathan
