Something is seriously wrong with my car...please HELP!!!
So I have not been able to build any boost since i installed my turbo kit. For some reason my car is running super lean at WOT. (By super lean i mean 14 and up!!) I have tried adding fuel VIA emanage to no success. I have upgraded to a walboro 255lph pump, but i did not change any of the wiring. I just plugged in the new pump. Could this be my problem?? I am completely at a loss here. The only reason i can think that i am not making boost is because the car is running so lean. I have checked for vacuum leaks, and my turbo is getting oil and spinning freely.
the car....
1992 sc300
1jz swap
t61 single turbo
mkiv 550cc injectors.
the car....
1992 sc300
1jz swap
t61 single turbo
It certainly sounds like a boost leak to me. Try checking your couplers too, a friend's WRX looked all fine but had a crack in the back of one of the couplers that you couldn't see at a glance.
wastegate is not stuck open, however i think i might be leaking around it. Would the vacuum line cause no boost? I was under the impression that the vacuum line would cause a boost spike.
i'm with everyone else, even though you say you checked it
sounds exactly like when my coupler blew off. . .
but iunno how you'd miss a leak like that if you put a cap at the throttle body, and then compress air into it at the turbo. . .
i don't think a manifold leak would cause 0psi at high rpms.
and a wastegate stuck open would make the car much louder. . .
