My car is not starting from a swap!!!
Old 08-08-07, 04:34 PM
SC904
SC904's Avatar
Default My car is not starting from a swap!!!
Hey guys. I just did a swap. Not a 1j or 2j. Just a v8 to another v8. The blown v8 is a 92 1uz and i swap in a 95 v8 1uz. The harness is different, ecu, vacuum host,etc.... i did it all, swap everything, plug everything, everything looks good until I tried to start the car. It didn't sart. It just crank... turn... but no sparks.... gasoline level is good, brand new yellow top, drain fill all the fluid except the brake fluid. I pull out the sparkplug and start the car and no spark whatsoever. Anybody know what's going on? Alternator is fine btw. So what now? Somebody please help!!! Thanks in advance.
Old 08-08-07, 08:20 PM
SC904
SC904's Avatar
No Body Knows?!?!?!
Old 08-10-07, 10:29 AM
hybridrift
hybridrift's Avatar
have you tried jumping the FP B+ in the diagnose port in the engine bay?
This happend to me when I swapped my 1jz and fuel pump, cranked but wouldnt start.
Old 08-12-07, 01:43 AM
bigmalik00
bigmalik00's Avatar
bump....did you get it started?
Old 08-12-07, 02:40 PM
SC904
SC904's Avatar
haven't have time yet... alittle busy this few days.... i think i found out why .... the timing is off .... any advice on how to fix that?
Old 08-13-07, 09:42 PM
zero442
zero442's Avatar
in my experience with swaps a good place to start checking is fuel line. often you will find that jdm engines have fuel lines slightly bent stopping fuel flow. Also a good place to check with no spark, assuming new spark plugs, are the grounds. check to make sure the engine is grounded correctly with a good un-corroded wire. another great place to check for no spark is the distributor and everything connected to it. Granted i am not in your garage and its is something hard to describe all the details of but thats the best i can give you right now.
avatarci
Performance
10-01-14 05:18 PM
mak89
Florida Lexus Club
03-27-11 01:52 PM
tuterz
11-03-08 12:02 PM
pmpdaddyt
NELOC
02-18-08 08:36 PM
mteele
01-09-05 05:03 PM
Quick Reply: My car is not starting from a swap!!!
