$1500 turbo kit
Old 08-11-07, 02:59 PM
1JZ300
1JZ300's Avatar
and yes you get what you pay for....if your going single, go alll out not cheap, youll just be disappointed and brake ****
Old 08-11-07, 03:07 PM
clean
clean's Avatar
build your own kit its alot cheaper, if you dont then find a good faricator there pretty cheap
Old 08-11-07, 03:30 PM
turbochris
turbochris's Avatar
Or do what i am going to do and just swap a 2JZ-GTE motor in......350-400whp with minor work. Then if thats not enough just start upgrading..
chris w
Old 08-11-07, 06:40 PM
Bean
Bean's Avatar
Originally Posted by 1JZ300
no.......piece your own kit together...get what YOU want, get the turbo YOu want, the wastegate YOU want, and BOV you want and ect....
98mkiv can do that. Of course I didnt expect anyone to read what I posted
You can lead a horse to water 10 $150 turbo manifolds or 1 $1500 manifold that flows slightly better. Yes the $1500 manifold has a lifetime warranty usually, but the $150 one has 1 year. You think you're going to replace 10 manifolds over 10 years? Or even own your car that long? It would take that long to come out even. Only reason I can see a better manifold being used is in the higher hp setups. If this is a low-hp setup, then why throw the cash around for a high-dollar manifold when you may end up replacing it for a different one? (like a T6 for instance). Its like running race gas in a stock 30 year old corolla.
WPB250
SC- 1st Gen (1992-2000)
07-24-10 08:04 PM
gman44116
Performance
12-20-09 10:58 PM
1sxyrxy
02-28-06 04:12 PM
95SC30095
28
01-17-05 09:04 AM
alanhp
05-04-04 02:03 PM
Quick Reply: $1500 turbo kit
