The Big Bad 1jz into SC400 thread
#46
Personally I'm getting closer and closer to zero hour.
I have my motor, tranny (auto for now), SC300 drive shaft and gauge cluster, igniter for the 1j, fuel cut defenser, fuel pump on the way.
I'm still intercooler shopping, need a few random hoses and new timing belt would probably be wise.... so if any has more info that we can put in, now's the time!
#53
Because to get over 500hp with a 1uz you need to get all new internals, tuning is tougher, and mods for the 1uz are more pricey. The 1UZ is a great motor, but not exactly the best bang for the buck... Especially considering you can do the swap, with a single, fuel, and a tranny to hold it and still be in for way less money than a stroker kit.
...or maybe you meant something else.
#54
This is very great information! This thread will surely come in handy when it is time for me to swap my 1uz out for a 1jz. Does anyone have any information on swapping a soarer 1jz and r154 5 speed into the sc400. If I was to get a hold of a soarer 5speed front clip would I have everything I would need to complete the swap? I know i will need the sc300 gauge cluster and driveshaft and i will probably be able to use the soarer motor mounts...somebody correct me if i'm wrong?
#56
Just curious what exactly doesn't match when fitting 1JZ tranny to the 400 driveshaft? Is there a length difference, or just the spacing difference on the 3bolt flange?
I'm just finishing up swapping an Aristo 2JZ into an LS400 and all that was required (DS-wise) was to swap the flanges from the tranny tailshafts.
#58
