The Big Bad 1jz into SC400 thread
#61
I'm just looking for alternatives to sourcing an SC300 front shaft when performing the UZ to JZ swap.
#63
Ok, what I have now:
1jzgte with tranny, ecu, motormounts
1jz ignitor
FMIC
sc300 drive shaft
sc300 gauge cluster
walbro 255lph fuel pump
Fuel Cut Defenser
I need:
Radiator Hoses
Battery relocation kit
jumper mod on gauge cluster
AC lines (I'll wait a little while for this)
What do I need to do with cooling? Should I just get an electric fan?
What else can you guys think of?
sc400 (duh)
1jz ignitor
FMIC
sc300 drive shaft
sc300 gauge cluster
Fuel Cut Defenser
I need:
Radiator Hoses
sc400 (duh)
#65
#66
There seem to be a lot more 1JZs from Chasers than Soarers available from the importers. Has anyone listed the differences between them aside from the oil sump positions? Any differences on ECU pinout and/or connectors?
#70
Hey MattSEG:
Which intercooler did you go with? I am looking at a body kit that would require a nice FMIC. What about your downpipe?
I got stock 1jz IC and DP from Supraforums, but I'm to the point where I might as well just spring for the after market goods so it gets the power I've been dreaming about.
You must be getting excited since you're close to doing it.
#71
I'm excited, but nervous too... I am going to have to do some more checking to the motor to make sure everything is good pre-install.
I'm going to fab up a DP and use stock exhaust for a while, I've heard about fitment issues with various 1j dp's, so that'll be another bridge to cross.
As for the FMIC I bought a blitz (still not 100% sure if it's a real blitz unit) that was on an s14 cut someone had bought. 2.5 inch inlets, decent sized. Due to the application it had previously, it seemed like a good sized unit for now... and it was like 160 bones shipped.
#72
Ok, I'm super confused about something.
To make things work right am I going to have to do any other strange wiring? I knew the sc4 gauges would never work right without tons of electronic manipulation so I got the sc3 cluster. Now aside from a few little things with that, and extending the ecu harness are there any other tricky parts with the wiring? Any bastardizing of the sc4's body harness?
#73
I just completed my 1JZ swap into a SC400. As for the Gauge cluster the temp works by grounding the black and brown wire. Speedometer is off by aprox 25% (about 10mph when cruizing at 70). I will try the tach tommorrow by jumping the resistor. So far so good, you may want to try the 400 cluster before you swap.
