The Big Bad 1jz into SC400 thread
Old 06-29-08 | 08:19 PM
  #76
yooooooooo's Avatar
yooooooooo
Default 1jz swap into sc400
hey... i just bought a 95 sc400 and want to do a 1jz swap tranny and all ... i dont wanna have 2 read through the whole post piecing together everything i need so if someone can give me a heads up of everything i would need to get to do this that would be sweet.. thanks
Old 06-29-08 | 08:54 PM
  #77
Jerzy_Boy's Avatar
Jerzy_Boy
ur gonna have to read and do some research. just wanted to say it b4 the flaming begins.
Old 06-29-08 | 09:43 PM
  #78
shern's Avatar
shern
WTF! If you don't have the dexterity to read through SIX pages of this thread, you definitely will not succeed in swapping a 1JZ. It will take ALOT more than these 6 pages on Club Lexus to properly swap a 1JZ. Give me a break.
Old 07-15-08 | 12:05 PM
  #79
alex8181's Avatar
alex8181
Hey guys, I got the engine and and just hooking everything up now. Can anyone clarify what to do about the alternator wiring. I have the 1JZ alternator and the plug that is in the rear of the alternator goes straight into the engine whereas the sc400 plug goes into the right side body wiring.
Old 07-15-08 | 03:55 PM
  #80
ZIP's Avatar
ZIP
I would say use the plug going to the body harness as those wires remain complete and intact. Thats what I used when swapping a 2JZ-GTE into an LS400.
Old 07-15-08 | 05:04 PM
  #81
LyFeWoRx's Avatar
LyFeWoRx
Awesome Thread - In For Results.
Old 07-16-08 | 12:40 AM
  #82
alex8181's Avatar
alex8181
What did you guys do with the O2 sensor for the cat converter on the driver side of the exhaust?
Old 07-16-08 | 01:53 AM
  #83
ZIP's Avatar
ZIP
Unplug from the connector(under carpet). Then cut the sensor off at the rubber boot with the grommet left to plug the hole in the floor.
Old 07-21-08 | 11:47 PM
  #84
alex8181's Avatar
alex8181
This thread is really awesome for us SC400 guys. Can someone identify this hose for me? It doesn't look like a hose I have on the v8 motor.
Old 07-22-08 | 04:50 PM
  #85
ZIP's Avatar
ZIP
Have you connected your heater core yet? I think that where that needs to go... it's just on the opposite side for a RHD.
Old 03-02-09 | 09:32 AM
  #86
dallasbean's Avatar
dallasbean
Default cluster swap
Do you have a diffrent diagram to swaping a cluster form sc300 to a sc400? Something with pics, im too dumb for diagrams. I have been researching to try to find wich resister you are talking about. When i had the cluster in my car the tach started to read wrong just like you said, but also every time i pushed on the button to put the car in gear my climate control will completely shot off. It does not do that with the sc400 cluster. Will that same resister eliminate that problem?
Old 03-11-09 | 05:51 PM
  #87
ProjectLex's Avatar
ProjectLex
Originally Posted by MattSEG
I'm looking for some information about:
A definite answer about if you need to swap radiators, and sizing.
Originally Posted by jm94tt
-If you are using the Soarer side mount intercooler, you cannot use the sc400 radiator. The flat intercooler pipe that runs along the bottom of the engine bay will interfere with the lower radiator hose outlet. I would recommend a sc300 radiator and coolant overflow as you will be able to keep your battery under the hood. Front mounts should be able to use the 400 radiator with overflow and possible battery relocation.
Is this definitive? What's the difference in specs between an OEM sc300 radiator and the sc400's?
Who is running their stock radiator after the 1jz swap? Please indicate if it's a 300 or 400 you swapped the 1jz into.
Let us know what radiator you're using post swap.
Thanks again to MattSEG for his work on this thread
Old 05-25-09 | 04:28 PM
  #88
xtra's Avatar
xtra
Default hello
Hello Everyone.
This thread is the greatest, it's exactly what i was looking for.
I got a killer deal on a Aristo front clip, I am going FMIC and keeping it auto so that solves a lot of my problems.
Can anyone confirm if the 2jz swap into a sc400 wiring is the same as this?
ok, here is what I can offer.
Section 2: Wiring
-Extend the 5 body harness plugs blah blah blah you have heard it before. I extended mine 24" and that is a bit much, i would say 18-20" would be good and still leave a good amount of slack.
-Extend the plugs in the engine bay to reach the power steering rack, and the heater control valve if needed.
-Use the body plug for the alternator, wrap the one on the engine harness with electrical tape and tie it out of the way.
-Move the blue and yellow wire on the white female body side plug to the female orange body( i think it is IK24) side plug so that when the 1jz side body plug with the blue/yellow wire is inserted the blue/yellow wires connect. This will get the Check engine light working.
-To make your temp gauge work, ground pin 24 on the same white plug on the body side(IK2). It is a brown/black wire between a pink and a black wire. I t-tapped into the brown/black wire and used the body ground behind the kick panel.
-There are two thicker black/orange wires on the larger gray plug coming from the engine that supply power to the igniter and injectors. You will need to find a good "switched" 12V source to power these, as they don't recieve any power from the sc400 body. I broke out the multimeter and found an unused by the 1jz pin that had a good 12v switched signal and spliced these two into it.
-I had to do the 12V mod at the fuel pump ECU to get the car to start. There are two thicker wires at the fuel pump ECU, (1)Green and (1)Black/Red14 GA. Cut these 2 and connect them. Insulate them well.
-You can do the R109 resistor mod on the back of the cluster to get a tach signal to the cluster, but it will read 1000 rpms or better higher than it really is. My car will bury the tach needle before shifting at WOT. I'm looking for a nice SC300 cluster to use.
Issues that I need help with (others please chime in):
- Air Bag light was staying on all the time (key on or off). The cluster was always plugged in when the battery was connected. I have the bulb pulled until I get it figured out.
- The 1jz auto trans is momentarily bouncing off of the rev limiter when shifting at WOT. Sounds like a machine gun. Does it for about a third of a second on the 1-2 and 2-3 upshifts.
I am sure I have forgotten stuff and I have yet to take pics. Hope this helps.
Old 06-01-09 | 03:46 PM
  #89
BladeGT's Avatar
BladeGT
Default Hydrofan replacement
Hi there I need to find a replacement hydrofan for a 1993 SC400. Does anyone know where to look for one?
Old 06-09-10 | 09:46 AM
  #90
MrFairlady's Avatar
MrFairlady
Mine needed the 2 Blk/brn wires moved to get power.
Fixed it.
