The Big Bad 1jz into SC400 thread
#92
The Crazy Deal with my Swap is:
1: I didn't have to bypass the NSS (93 SC400 w/ 5spd swap and 1jz).Stock wiring worked fine.
2: My Fuel Pump and Other accessories (safc is only thing Period thats hooked up/dash/radio/ac all unhooked) stay on After the Key is turned off (motor turns off). - I have to pull the EFI Fuse or Relay for the car to Shut of everything else.
I even Started the car with the Fuel Pump ECU UNPLUGGED and the car runs Like it does with it.
Somewhere in the wiring the ECU or something must be getting power from a Relay that will Not shut off.Any IDEA's?
Car is totally bypassing the Fuel ECU completly it dosen't seem to by using it.
Na sorry..Sold it to a co-worker (tech at work)
#93
na when i drop my 1jzgte motor in my supra i used a nissan altima thotle cable works fine wit me and all the driveshaft will for longs the trans is a w58 trans but when u got to a five speed r154 trans u got to change yur diff and yur axle but mkii 7mgte supras come with all that just look for a part out they are y where but they blow up very easy
#98
i probably should have created this thread when i did a 5spd / 1jzgteVVTI swap in my sc400 last year.
also, FWIW, i believe the 1jzgte VVTI is the cheapest swap you can get for our cars on ebay right now.
i got mine for 1200+200 shipping. that's 1400 shipped...
people are scared to swap them because they think it's some alien engine that powered a UFO, so they are cheap as hell on ebay.
#99
#100
#101
#103
a group of people you can go to for support when you spend too much money modding your engine?
driftmotion makes a nice hybrid upgrade for the CT15b stock turbo with which you can make like 350+whp. i believe they just put a mitsu 20g compressor wheel in the stock housing. i'm not sure what kind of setup you're rocking, but 350+whp isn't bad... and if you're going to be getting cams, a 70mm turbo, and an EMS system, who gives a ****? a lot of things have to be custom at that point anyway, right?
#104
what exactly do you mean by "aftermarket support group?"
ps will do lol
