The Big Bad 1jz into SC400 thread
#106
what exactly do you mean by "aftermarket support group?"
a group of people you can go to for support when you spend too much money modding your engine?
driftmotion makes a nice hybrid upgrade for the CT15b stock turbo with which you can make like 350+whp. i believe they just put a mitsu 20g compressor wheel in the stock housing. i'm not sure what kind of setup you're rocking, but 350+whp isn't bad... and if you're going to be getting cams, a 70mm turbo, and an EMS system, who gives a ****? a lot of things have to be custom at that point anyway, right?
#109
I got my 1jz/trans/ecu/wiring swap for $1250 shipped to my door from Canada!
JZX90 Chaser, so I too had to drill the oil pan out, and find the ECU plug from a Mid 90's V6 Camry / Mazda V6 626.
The 20G Compressor wheel will do 500 AWHP on a 2.0 4g63.
That is with a 7cm2 hot side, or around .6 A/R
A CT15 with a 20G compressor wheel would be great for the "Sleeper" aspect.
"Stock turbo, see"?
"Stock turbo, see"?
#111
#113
1JZ Single SC400
Got a question about the cruise control cable. What length will i need to run the cable behind the motor and on top of the intake manifold? Dont like the idea of it coming across the valve covers. Has anyone done this or hid the cable somehow and be still 100% functional?
#114
