? about a/c compressor going out
Ok so today my car started making this horrible shreaking noise. Like screaming bloody hell murder. Turn off the ac compressor the car sounds perfectly fine. Is this a common compressor going out issue? i'd hate to be completely wrong. thnx for any help.
Keeper of the light
It's the bearing in the clutch. It's usually cheaper to buy a whole used unit than to buy a clutch and have the AC disassembled and have a new clutch pressed on, then completely reinstalled. Fact of the matter is that if the bearing is that badly worn, the clutch is also and it wouldn't be able to be reused. I actually have a spare AC unit from my SC4 that I keep as a backup, but I don't think I'll ever use it. Unfortunately I do not know if it would even fit the Sc3. Likely not.
You might what to check the crank pulley the rubber in the middle part wears out and will make that noise when the extra load of the ac. If you start your car with the ac off will it make a quick screach and then go away?
k lemmie give you two quick scenarios then.
1. i was flooring it down the freeway. turn the ac on and the sound comes back. still flooring it i turn the a/c off it goes away.
2. I was in the fast food drive through the a/c was off i was crankin the wheel all the way to the left to make the turn and it screeeced the same noise for a sec. which didn't make me understand.
I'm going to drive with the a/c off and see how much it happens and in what instances. this noise is completely unbearable. its soo loud in the engine bay its hard to tell exactly what its comin from.
I would expect to see ribs worn down and perhaps inconsistent wear on those ribs.
Also, you can watch the car idle and check each pulley for round (as it is easy to see when they are spinning). That would only take a second.
RedPhoenix
Performance & Maintenance
04-14-09 05:22 PM
