ClubLexus' Top 20 Fastest SC300's
Old 09-10-12, 06:30 PM
  #136
8secsc300
8secsc300's Avatar
Default Fastest SC300 in the US maybe
I just finished my 92 Lexus SC 300, first time down the track I ran A 9.0397ET at 143.27mph. Its a GTE 3.0lt with billet mains, CP pistons, Manley Turbo Tuff rods, Kelford cams,Haltech engine managment,Injector Dynamics injectors 2000cc, 74mm Bullseye turbo and backed with a ATI TH400,JDM diff 3.23 gear. I have a crued video of the pass and a time slip to prove it. The car is only going to go faster. This pass was done 9/07/2012 and i took it to the IFO event in Noble OK on 9/09/2012 and took second FIP with a 9.15 at 151mph.
Old 09-10-12, 07:40 PM
  #137
blk&blu*j
blk&blu*j's Avatar
Very nice 60ft. What tire and rim are you running?
Old 09-10-12, 07:55 PM
  #138
8secsc300
8secsc300's Avatar
Thank you, M/T 28 x10.5x15, Weld prostar 15x10 rear and skinnies up front.. The turbo is maxed out and we are not pushing the motor at all it seems... we are upgrading the turbo to a custom billet 76mm and hope to get into the mid to low 8s!! We have chassis tuning to do still also..
Old 09-10-12, 08:49 PM
  #139
blk&blu*j
blk&blu*j's Avatar
what diff are you using?
Old 09-10-12, 08:57 PM
  #140
blk&blu*j
blk&blu*j's Avatar
Sorry missed the diff, what fuel, stall and how much power? My 74 Bullseye is doing 900ish at 30-31 psi through a getrag
Old 09-10-12, 09:23 PM
  #141
whiteSc3
whiteSc3's Avatar
Congrats nice pass, post up some pics and details!
Old 09-11-12, 05:16 PM
  #142
97GSTAT
97GSTAT's Avatar
Here's a video of a dyno session for 8secsc300 aka Marty's car. I don't have the track runs, so he'll have to post that up. Also the dyno we are using is a Dyno Dynamic also known as the "Heart Break" dyno for it's low number reading. But awesome for tunning. Enjoy.
Old 09-11-12, 05:48 PM
  #143
8secsc300
8secsc300's Avatar
we are using c16 right now and we are a little over 1000whp at 31psi atm.. we had to dial it down because the turbo was getting to hot the stall is a ati 7800 10''
Old 09-11-12, 05:57 PM
  #144
SChema
SChema's Avatar
Good combination you have there. What type of head work do you have done? I'm minutes away from Thunder Valley in Noble, didn't get a chance to make it out there. Always to good to see the SC putting down some quick times.
Old 09-11-12, 06:00 PM
  #145
whiteSc3
whiteSc3's Avatar
Whats the car weigh? Any N20? Your stall is a 7800!?
Old 09-11-12, 06:48 PM
  #146
8secsc300
8secsc300's Avatar
Thanks guys, the car weighs 3000lbs with out driver and 3250 with... We are using a 100 shot to spool off the line only..
Looking into the pte 7685 billet now Should do the trick
Old 09-11-12, 07:42 PM
  #147
lilSCsteve
lilSCsteve's Avatar
8secs, that's a SICK SC...great build. Do you have a build thread some where? If so, please post up...thx!
Old 09-12-12, 12:07 PM
  #148
blk&blu*j
blk&blu*j's Avatar
Not to create a big pot of ***** but I call foul as 31 psi through a 74mm Bullseye on a TH car and making a 1K is not possible through that turbo its verily possible to break a 1000 on a stock compression 3.0 L gear car with that turbo never the less through a TH and your trap speed is out of line for a 1K car.
Here is a perfect example of a 1k car with a Glide.
Old 09-12-12, 12:41 PM
  #149
97GSTAT
97GSTAT's Avatar
http://www.youtube.com/watch?v=7W3CP5GFn_o
If you watched the video I posted you will see it made 878 whp on a dyno dynamic dyno, add 12% and you will get what the car would make on a dynojet. The turbo maxed out on that pass, like Marty said the shot is only of the line. You can all BS all you want the facts are thee and are proven with REAL world data. The times don't lie nor do the dyno numbers.
Also you do realize that the car you posted up weights a whole hell of alot less then an SC300, right? Weight makes a HUGE difference when you are starting to make big power. Oh and the car is not running stock compression, I'll let Marty tell you what it is being that it isn't my car.
Old 09-12-12, 02:25 PM
  #150
blk&blu*j
blk&blu*j's Avatar
Thumbs up
The car I posted is a personal friend of mine, and at the time of that race, weighed in right at 3000 with driver on a 3.0L with some compression changes through a glide on a single fogger for spool tuned on a V1. Similar sized Turbo but BB and E-85.
I'm not bashing the car its a really nice looking car nor the build up of the car I just feel like the #'s are definetly off with the trap speed and the 60ft
Quick Reply: ClubLexus' Top 20 Fastest SC300's
