ClubLexus' Top 20 Fastest SC300's
#122
just got back from clay city dragway. the same track that holds the record for 2nd fastest sc in the US set by hal at injected performance (9.39) and i ran a 9.40 sideways until i blew an intercooler pipe, blew one (same one) every pass. i will be correcting that problem and setting the record within the next week or 2. i will post the time slip in the morning when i get up
#124
Might as well update this one:
10.96 @ 125.2 - Witckraft - 2JZGTE, TH400, 58mm, AEM (1.73 60')
slips: http://home.comcast.net/~peter.tomeo/slips.jpg
#125
#127
I hope to land up the list next time I get to the track. I went before I pulled the engine this last time and upgraded some thing. I did 3.3 @111mph and a 2.3 60'. I'm hoping to hook with some ET streets and break into the 120mph.
#128
umm 3.3... i dont think it was 3.3, maybe 7.3
#133
stock head, L19 head studs, ferrea dual springs, GSC1 cams.
One TT fuel pump w/-6 feed, 630 injectors, and FPR.
Tuner for now is a JDM blitz access ECU w/safc
I dyno'd the car stock fuel, head, cams and 14lbs of boost. I did 470whp uncorrected on a dynojet this is what it was at when I went to the track. I then did all the upgrades above and with the meth tuned the car for 23lbs. I never dyno'd it but it was a big difference.
#134
OK finally went to the track.
60' 1.55
ET 11.29
MPH 129.53
GTE, v160, pte6262,v160, TRD LSD W/gs400 3.26 gears, 24-28 psi, meth/water injection and......ET Streets
60' 1.55
ET 11.29
MPH 129.53
