Speedometer accuracy and LSD
Old 09-06-07, 09:42 AM
97-SC300
97-SC300's Avatar
from a 95 supra.
Old 09-06-07, 05:04 PM
97-SC300
97-SC300's Avatar
ok did some more research and studied the wiring diagram today.
found out there is a devise called "Yellow Box" that could be purchased at.
http://www.blackrobotics.com/yb_home.htm
they have a diagram of how it should be wired in.
my question is i was looking at the wiring diagram for teh 97 sc300 of the
#1 vehicle speed sensor that is located somewhere on the transmission. and it looks like that is where the Speedo gets the signal from. on the directions of how to wire this unit in it says to obviously hook up the power and ground. and then to hook up the IN and OUT signals. looks like out cars have a 3 wire speed sensor if you look at the wiring diagram that 2JZ_SC posted. and if you look at the schematic for the speed sensor look slike the yellow wire is only for the 12v power. i needed to know how which wire color is teh IN and which is the OUT. and how would i wire this in.
Old 09-06-07, 06:03 PM
DIrEctQL
Chicago Lexus Club Moderator
DIrEctQL's Avatar
Get AEM EMS and no need for stupid yellow boxes.
Old 09-06-07, 06:15 PM
97-SC300
97-SC300's Avatar
it would be stupid for me to get an AEM EMS on the stock motor.
Old 09-06-07, 06:39 PM
2JZ_SC
2JZ_SC's Avatar
A little on the "over kill" side but try this. Look at page #1577. I beleve that it is #3
File Type: pdf
Old 09-06-07, 06:49 PM
97-SC300
97-SC300's Avatar
this just shows on how to test that sensor. i need to find out if i purchase this yellow box. if it will work on out cars and on which wires are the signal In and which is Signal out. 2JZ_SC thank you for the wiring diagrams bro.
Old 09-06-07, 07:05 PM
2JZ_SC
2JZ_SC's Avatar
If you put battery + to terminal 1 and battery ground to terminal 2, check the voltage change on terminal 3, The voltage change is what the "computer" or "processor" is looking for. That would be your output to the cluster.
Old 09-06-07, 07:07 PM
2JZ_SC
2JZ_SC's Avatar
I do not know if it will work on our cars, but if it dose run it in-line on terminal #3 (sorry, not looking at the EWD to tell what wire that is)
Old 09-06-07, 07:11 PM
97-SC300
97-SC300's Avatar
just looked at the EWD and it look slike the sygnal wire is that blue/red one, the power is the yellow and the ground is the red. is taht correct in your opinion.
Old 09-06-07, 07:13 PM
97-SC300
97-SC300's Avatar
i will install the LSD diff next week and i will see if it really changes the speedo. if i dont like it i will buy this yellow box. and post a DIY on the install. also would you splice this in right at the sensor and run the wires inside when i would mount the box maybe under the seat somewhere.
Old 09-06-07, 07:14 PM
2JZ_SC
2JZ_SC's Avatar
That's how I read it.
Old 09-06-07, 07:16 PM
97-SC300
97-SC300's Avatar
thanks a lot man, whats your name BTW? do you have any pics of your car. really appriciate the help. I am Dmitry.
Old 09-06-07, 07:18 PM
2JZ_SC
2JZ_SC's Avatar
once it gets into the combo meter it splits to the speedo head and the trip comp.
Old 09-06-07, 07:19 PM
2JZ_SC
2JZ_SC's Avatar
I'm David. When I get home I'll find some pic of my lex.
Old 09-06-07, 10:37 PM
DIrEctQL
DIrEctQL's Avatar
It wouldn't be stupit. You'll have to get a solution for all the problems you'll come to when you go turbo. AEM EMS is the solution. It also comes with a base map for stock car so you can drive it around. Althrough you can find a cheaper way to fix the problem you will not have to hack your harness or much else.
Quick Reply: Speedometer accuracy and LSD
