How do I ground my Igniter on the 1JZGTE??
So in trying to resolve my issues on my 1JZ, it terms of that annoying Rev limitter type thing.
At first my car was not revvng past 2800K so I found out that the red wire on the TPS was not getting a 12V signal, so I hacked it and now I am revving close to 4K but I still get cut under load.
So my question is I dont have the mount for my igniter that sit on the body of the car, I read that this is the actual ground for the igniter, so if its just sitting there:
Is it grounded Yes or No?
Next I will check my ECU caps....
so I take it that your boostin fine without no igniter bracket, i am edging to a bad lead or short in one of the wires, I think it could be the crappy ECU.
I was looking on Supra mania, and quoted from OneJoeZEE:
"My car was doing the same thing last time I installed my harness. It turned out two connectors were switched. The connector for the hydro fan ECU and another connector(can't remmeber which one exactly) are identical. And when switched, the fan would not run on high and car would not rev past 2500 or whatever RPM it was. Switched them and everything was ok. There's only one other connector in there that's the same as the fan one so it should be easy to spot.
Yes, it sounds trivial but you should check just to make sure..."
So do we even have a Hydro Fan ECU I thought only the Supra 1J
s had the hydro fans??
6SOARER
Performance & Maintenance
12-06-11 09:06 AM
