Click, click, vrrooom (SC300)
Old 09-10-07, 02:26 PM
RDKUT
RDKUT's Avatar
Default Click, click, vrrooom (SC300)
Maybe somebody else has also had this issue..
Recently, when I turn my car over to start it just goes 'CLICK' then, I try it again and, 'CLICK' try 3 or 4 more times then finally it will start.
Sometimes when I get in it starts up right away, sometimes I have to try turning over 20 times. Has anybody else has this issue?
Also, occasionally my left blinker will blink twice as fast as my right blinker!
Anybody have any ideas?
Thanks!
Old 09-10-07, 02:30 PM
1JZsoarer
1JZsoarer's Avatar
thats your alternator(sp?) going bad well mostly..
Gunnar
Gunnar's Avatar
5speed car? My Nissan truck used to do that when the clutch safety relay was on it's way out.
Old 09-10-07, 03:05 PM
93SC300.
93SC300.'s Avatar
i had this issure just rec ently and then it stopped for a while and i was so happy. they one day it just clicked and that was it. turned out to be the starter. replaced it and it was good as new. gl. make sure ur starter wires that run from the attery are clean and ur getting juice through them before u go and replace cause that could be a problem also. coutn on replacing the starter and it takeing u while to do. ITS A JOB!!!
Old 09-10-07, 03:36 PM
PearlSc1
PearlSc1's Avatar
Yep, i had the same problem as well. And as 93Sc300 did, i replaced my starter as well. Now its good as new
Old 09-10-07, 03:40 PM
Dx3
Dx3's Avatar
Be thankful you have an SC300 and not an SC400
Jonny
Old 09-10-07, 04:32 PM
RDKUT
RDKUT's Avatar
Thanks all, going to check out all these different suggestions!
Old 09-10-07, 04:38 PM
KC95SC400
KC95SC400's Avatar
Replace or clean the contacts in the starter solenoid and you won't have to replace the whole starter.
If one of you blinker bulbs go bad or have a bad connection, the side with the bad bulb will blink fast. Next time it does it, bang on the front lens and see if it changes, if not try the rear.
KC
Old 09-10-07, 05:06 PM
got_trd
got_trd's Avatar
all symptons lead to the starter
Old 09-10-07, 07:42 PM
NYCsc300
NYCsc300's Avatar
its the starter...
Old 09-11-07, 09:33 PM
orangecar
orangecar's Avatar
I had he same problem after I got my sc300 cleaned the contacts and she got it goin again
Old 09-11-07, 09:45 PM
na4now
na4now's Avatar
That should have nothing to do with the alternator. The clicking means your selinoid is working. I would agree with checking your + and ground on the starter, as well as on the battery.
Old 09-13-07, 12:01 PM
RDKUT
RDKUT's Avatar
Could anybody describe where the starter is? I bought a starter repair kit from ebay but I'm having trouble finding the actual starter!
Thanks!
Old 09-13-07, 12:35 PM
KC95SC400
KC95SC400's Avatar
The solenoid is only half working. Don't know the correct terminology, but in the solenoid there is a round, spring loaded contact that is pulled down when power is applied. It's pulled down to two L-shaped contacts to transfer power between them which in turn sends power to the actual starter. The clicking noise is the spring loaded contact being pulled down to the two L-shaped contacts. The car won't start because the contacts are likely quite corroded and there is too much resistence to supply enough power to start the car.
Replace or clean the two L-shaped contacts, clean the round contact (plunger I call it) and it will be as good as new.
Not trying to sound smart or anything, but I've worked for Toyota for 6 years as a tech and have only ever replaced 1 starter. It was sticking on, kept turning after the engine started.
SC400 = under the intake manifold.
SC300 = don't know, never touched one, but I'd guess it's on the transmission bellhousing somewhere, and should be pretty easy to get to from underneath the car.
KC
Old 09-13-07, 04:21 PM
RDKUT
RDKUT's Avatar
thanks, cant wait to get it running again!
Quick Reply: Click, click, vrrooom (SC300)
