The Stock 2J in the Sc300
#31
thanks for tha info I think you all won me over with the JZ I guess ill save the LS1 for the next one i build....I gotta Question the GT28's will that have the same effect on the 2jzge or will i have to go with a 1jz swap
#32
#34
http://www.supramania.com/forums/showthread.php?t=46713
This thread should give you a good idea of the level of fabrication required to pull of the twin GT28R's. There is a lot of plumbing, but the performance is great.
Ryan, SC400T, is putting twin GT28R's on the V8 is his SC400. He is expecting to make 600+whp with absurd spool. The GT28R's on the 2JZ would simply mean quicker spool than on the 1JZ (where the link above is advertising full boost -20psi- at 3800rpm).
The number of times that an na-t build has included twin GT28R turbos is likely a single digit number. Such a set-up is generally considered difficult and not worth the added headache in custom fabrications when a single turbo can spool similarly fast and blow similarly hard without the headache. Nevertheless, dual GT28R's would kick ***.
#36
I think I'm going to try my luck with the 2JZGE..I think....The LS1 sounds tempting because it has no turbos lol no IC piping no intercooler.... and i already have the tranny..And the tranny for the JZ is a handful the six speed is expensive then i gotta find all that stuff for it...Ill just ask my so of my budds because im stuck in the middle
#37
if you get frustrated quick, do not try the LS1 swap. that will take enormous amount of patience.
The R154 transmission is a cheaper alternative to the V160, and it will hold about everything an na-t can throw at it so long as the clutch can keep up. I got mine for $100, and I am using Genuine Toyota Parts to convert it to use the appropriate shifter location for the SC.
My advice is to do more research. Needing response and top end on a drift car the 61-67mm turbo range is likely the sweet spot. Search this forum and clubna-t. Also scan Supraforums for various set-ups to see what people have produced with a given set of modifications.
#41
#42
#43
Yeah those cars are AE86's that weight 1800 pounds so 100 hp is all they need compared to 3500 pound car (sc300 at stock weight needs a lot more hp and a lot more torque to get moving) besides the 4age that comes in the AE86 100 hp is a lot for that motor...I had a LS1 in my 240sx for 1 1/2 year's with anything seriously going wrong with it...Now I might be dropping one i my SC not sure yet that twin GT setup dude was telling me about about sounded good so i don't know I know when i complete my research on the 2JZGE I've been on the ClubNA-T website and gained a lot of info on the motor and I just need to experience the motor for myself...to have a opinion about this motor b/c i know squat about it....So U say the 2J is more reliable ok I don't but i do know that the LS1 is because i own one....
#44
yeah ... those AE86 are the ******!!! but i was talking about 240`s taking out LS1 swapped cars.. lets see that LS1 in the SC!! .. you`ll probably be the first to do it...
#45
Yeah that would be cool...I hate going into tandem's with those things there so fast it takes a skilled driver to keep up with them because they barely break traction unless its a Hybrid 86 with a SR20DET inside of it then its easier....
