Couple of (Dirty Engine Parts) Questions
Old 09-16-07, 10:40 AM
100mgbluep
100mgbluep's Avatar
Default Couple of (Dirty Engine Parts) Questions
To start i have a 94 sc300 w/ 134k.... While replacing my plugs i noticed my throttle body was super dirty, what should i use to clean all of that up? Also, after i changed my plugs, the next day i drove to school and back and that night i was driving on the highway and my check engine light came on and has stayed on ever since. What could it be? Thanks for your time...
Old 09-16-07, 11:36 AM
LSEGHATCH
LSEGHATCH's Avatar
Not sure about the cel, but what do you mean by your throttle body being dirty? Take it off, remove sensors and hoses then spray with brake cleaner.
Old 09-16-07, 11:44 AM
100mgbluep
100mgbluep's Avatar
Dirty as in theres dirt/guk inside the throttle body, coming from the left side of the engine.
Old 09-16-07, 12:13 PM
Black_SC
Black_SC's Avatar
i used brake cleaner and made it shine.
Old 09-16-07, 12:27 PM
neurocity
Neu`roc´i`ty
neurocity's Avatar
Engine Question = Engine Forum
Please title threads so people can search for them later.
Old 09-16-07, 12:34 PM
100mgbluep
100mgbluep's Avatar
Alrighty, anyone have any thoughts on the engine code?
Old 09-16-07, 01:11 PM
Fireblaze
Fireblaze's Avatar
Do you feel a difference in the car?
Old 09-16-07, 04:37 PM
100mgbluep
100mgbluep's Avatar
Doesnt seem to go as fast...
Old 09-16-07, 04:48 PM
Rexn30
Rexn30's Avatar
Just run to Advance they will scan it for free.
Old 09-16-07, 05:27 PM
Dx3
Dx3's Avatar
NO they won't. They only do OBDII and 94 is OBDI. Just pull the code yourself with the TE1 and E1 pins and you will have your answer.
Jonny
Old 09-16-07, 05:30 PM
Rexn30
Rexn30's Avatar
Doh, I didn't read, was thinking his car was 96+
Old 09-16-07, 05:43 PM
100mgbluep
100mgbluep's Avatar
Jonny
me = lost.. i have no idea what te1 and e1 pins are
Old 09-16-07, 05:51 PM
Dx3
Dx3's Avatar
Search "pulling codes" in the SC section and it will give you a write up on how to pull the code for your check engine light and what it means.
Jonny
Old 09-16-07, 08:54 PM
100mgbluep
100mgbluep's Avatar
Alrighty, took everything apart again and i put some old ngk's that i had laying around that i thought were new. Basically they failed... so i got some new ones and cleaned up my throttle body while i was installing the new NGK's and now everything is perfect! Except i need to replace my valve gasket because its leaking... But other than that my engine runs like she was new!
Old 09-16-07, 11:41 PM
Fireblaze
Fireblaze's Avatar
I was going to guess a mis-fire code because that happened to me (I cleaned my engine though)
edmondt
12-21-11 11:33 AM
OLDsc4me
29
04-22-09 03:49 PM
Robkarlee
10-02-06 09:56 PM
olddog
GS - 1st Gen (1993-1997)
03-20-06 06:08 PM
LSPiNoY
10-14-04 12:00 PM
Quick Reply: Couple of (Dirty Engine Parts) Questions
