how to check transmission fluid?
it happens in between shifts and while in gear completely.. in between shifts.. i let of the clutch... has to be almost completely out before it engages.. with a thud noise.. and.. while in gear completely foot off the clutch pedal.. i give a little gas then it shakes... then it'll start moving smoothly.. also i have to rev pretty high.. for it to drive smoothly and shift smoothly.. during gear changes.. while in neutral.. reving.. the car revs fine..
gunar.. if you're not too far away .. maybe i can come have you check it out.. if you're not busy also..
You're in KC right?
Does it feel like it jerks like something's moving around below you or like a car bucking? Might want to do a tuneup on it. I plan on changing my transmission mount before too terrible long, doesn't seem too hard.
As car as clutches, mine went out a week after I got the car, and Black_SC has been through like 15 stock clutches in a year and a half or whatever.
hush you.
hummm well i've been wanting to change my transmission fluid as well since I got my car but it's in such an awkard spot to refill, is there an easy trick to filling it?
