Intercooler piping
Just curious where you all got your intercooler piping for 1jz. There a website that sells kits that fairly bolt up? I want mandrel bent pieces so it isn't shrunk around turns. Thanks !
You'll have to go custom to get the fit you are looking for. 1jz's are still somewhat rare to the scene especially in sc's, so there won't be a kit out there that will fit.
You can buy piping kits, but they aren't model specific, they just come with what you SHOULD need and even then you will have to have it cut and welded to your application..
any custom bent MKIV 2JZGTE FMIC and piping kit bolts right up to the stock twins.
You can find used greddy mkiv 3 row kits for cheap, and new knock offs even cheaper.
My cold side is 2.5" mandrel bent steel, hot side is 3" mandrel bent aluminum. Cold sides on the single turbo is really easy. Just go down along the frame rail. Minimal bends and it's nice and hidden.
