engine leak
I just finished timing belt car starts fine then i notice a leak from by the harmonic balance and looks like coolant fan fluid (red) its not rushing out or anything. can this leak be from my crankshaft seal if the fluid is red please help
Location: Sideways on the Yellow Brick Road! < Thats KS!
I think were talking sc400 since thats what your profile says, right?
Sounds like a fan fluid leak. Probaly from the pump area, did you get the washers back on the banjo fittings? Those washers are the seals.
thanks ScottURnot i will sure try that cause i think i misplace the washer for the banjo fitting 1 question will it leak on the harmonic balancer from the banjo fitting for the engine fan coolant and would you be able to get me a part number for the washer thank you in advance
