MAF Clean didnt work
So I took my maf out to clean and I sprayed it with MAF cleaner. IDK it was some **** at Checker. I let it sit for like 10 mins and then I put it back in and I was idleing ****ty and the Check engine light was on. So I pulled it out again and let it sit for like 4 hours and it still didnt work. It works untill I drive alittle. then when it gets below like 1500 the trac light turns on along with the check engine light IDK it is messed up. any help would be much thanked.
i have the exact same problem! after i clean my maf with lighter fluid, it idles rough and rich, but when im like above 1500 rpm the problem fades and engine check is gone, when i come down below 1500 rpm down to idle the problem starts and the check engine is back.. i hate afms! why didn't toyota use map sensors in the first place! help guys!
