550cc Injector Upgrade
I believe the SAFC can control injectors up to 50% bigger than stock right? At least that's how the Honda guys figured it...so a car that had 550's can control up to 825's in theory.
I had 650cc injectors on my Mitsu 3000GT VR4 (stock injectors were 360cc).
(650-360) / (650) = about -44% correction. (which was around where I was at on my s-afc).
Thanks guys, a couple of choices, that exactly what I needed to know.
550cc is 50% of 1,100cc.
Double the stock injector size. at -50% correction on the s-afc, u could run 2x larger than stock injectors. I'm speaking from experience.
I ran 650cc on my 3000gt, controlled by an Apexi S-afc. Stock was 360cc.
(650-360) / (650) = -44% (which was approximately the correction I used on the s-afc).
Get it?
Tell me I'm wrong.
(825-550) / (825) = -33%.
Although the car has larger than stock injectors, by using a -33% correction on the s-afc (give or take a few percentage at each RPM point) the ECU still "thinks" it's got stock injectors. 67% of 825cc is 550cc.
Eh, it's difficult to explain. Sorry if I was being an ***.
I wasn't saying that they could handle 200% of the stock size, but rather 150%. So a car that came stock with 550's could handle 825's...I don't see what you two are arguing about.
(New Injector - Original Injector) / (New Injector).
(825-550/ 550) x 100% = -50%
100% of x = x * 1.0
90% of x = x * .9
...and so on. It also goes the other way so that
110% of x = x * 1.1
Something 50% larger than 100% is 100% + 50% = 150%
When you divide x / the % or in this case 50% what you're really doing is x * ( 1/.5) which becomes x * 2 which is clearly wrong.
The point is you got the values mixed up as to what plugs into where with your percent error formula in relation to what you're comparing.
Yup you're math is completely wrong.
550cc / 50% might be 1100cc but thats not the right calculation; you're basically calculating 200% of 550.
50% larger injectors is from the perspective of the original injector size. at 550cc stock injector mapping; 50% bigger injectors is 50% OF 550cc tacked onto 550. So its 775cc since 550/2 = 225, 550+225 = 775
At 330 it is 495 since 165 is half of 330.
Thats cool you ran 660s on your VR4 with such small stock injectors, that doesnt make the math right unfortunately. Running rich is doable, running lean is not. In fact the car will autocompensate to a large degree when under closed loop.
Tech Info Resource
The ECM will compensate +/- 20%. It also has short term and long term fuel trim. ST is +/-10% and LT is the full +/-20%. When ST exceeds 10% it affects LT. You can check this by measuring Vf. If the ECM thinks no adjustments from the factory settings are needed, Vf will be 2.5v. +5v is rich and 0v is lean.
Most importantly - these trim factors get applied even in open loop, so whatever the O2 sensor tells the ECM in closed loop, the ECM applies in open loop. This is why it is so challenging to get a Toyco ECM to leave the fuel alone after you trim it with a piggyback. If you try to trim fuel in closed loop, it just adjusts ST or LT (or both) until you are back at stoichiometric, AND it applies that same factor when you are in open loop, so all your tuning results in a net gain of zero. This is why they have a TPS input - so you can make WOT/open loop changes without having the ECM correct.
If my calculations are, in fact, wrong- then how was I able to successfully control 650cc injectors on my 3000GT VR4? (stock size = 360cc).
There were guys on 3SI running 720cc injectors on their VR4's. 720-360 divided by 720 is 50% correction- which was in the ballpark of where they were at.
When I had 550cc injectors on my VR4, I was at -34% correction or so. When on 650cc injectors, I was in the -43% or so. When my buddy was on 720cc injectors, the s-afc was almost maxxed out to -50%.
Car ran just like it did when it was stock. Stoich a/r when it was idling, cruising, and low/partial throttle- and a solid A/R when i was at WOT and full boost. Not too lean, not too rich- just right.
I was under the impression that the percentage of negative correction was:
(New Injector cc- Old Injector cc) / New Injector.
I'm speaking from personal experience(s).
http://www.team3s.com/FAQ-AFCtuning.htm
I used this as a basic reference when installing an apexi s-afc on my VR4.. back in 2002
Actually, using an SAFC to control large injectors does "work" to control JUST the A/F at a basic level, but you need to understand what's going on beyond the A/F that you're correcting. Since the SAFC doesn't control PW, and only alters airflow, you're gonna run into much bigger problems with too large an injector, and that's timing advance. The stock ECU has timing maps that are ALL airflow based. The less airflow the ECU sees, the more it'll advance the timing. So while you can look at the A/F and be at a perfect 11.5, if you pull out too much airflow, the timing will advance itself A LOT. Pulling out 50% fuel on an SAFC is dangerous, and most people don't even realize that the cylinder pressure is increasing because they don't know what the SAFC is doing when used under conditions like that. If you're going to use an SAFC to tune with very large injectors, use an AFPR to basically "trim" the injectors capacity at WOT. The drawback to this is that the bottom portion of the map becomes hard to tune, but I'd take an erratic idle over a blown motor any day of the week. I do professional dyno tuning on AEM's, Motec's, ecu reflashing, and have done pretty much all the piggybacks, and have seen this happen way too much.
