JDM vs. USDM...
Tech Info Resource
ECM specific difference that makes a big deal - JDM is MAP (speed density) and USDM is MAF (mass airflow.) This makes a big difference for piggybacks.
being a jdm ecu i thought i would make my speedo off...because the run KPH and we use MPH...but i found out that it has nothing to do with ECU...and its all in the speed sensor in the tranny i have which is W58
also could you guys break down those BIG differences the two have...
So... If I bought a JDM front clip it would still be a pretty big pain to install? does anyone have a rough estimate of the addtional cost after buying the front clip?
So the W58 wouldn't work huh? Dealing with the harness sounds like a PITA but besides that, it doesn't seem too bad.
757jetip
Performance & Maintenance
13
08-09-07 11:24 AM
