SAFC WOT vs regular driving
Old 10-20-07, 12:22 AM
TTSC3
TTSC3's Avatar
Originally Posted by LexAnt
you don't have to disconnect the stock o2 sensor to run a wideband and tune. i have mines setup so that it runs as dual function. i have a wire from the controller running to the ecu to act as a narrowband while another set of wires run to the included gauge to act as a wideband. i have my wideband placed in the header o2 location to keep it ahead of the cat. i will note that when i took it to a dyno to tune, compared to their o2 in the tailpipe vs my wideband, their o2 sensor read 1 point leaner than mines.
The tailpipe sniffer isn't a good place to get readings from. The reason they were a full point leaner is because their sniffer was picking up ambient air. Also, to answer the question above, you shouldn't have to worry about the air density causing you much of a change, if any at all. If you were forced induction, it would be different, but not so much with N/A. Normally, when I tune the N/A cars, they come in for a one shot deal...unless they upgrade again and need a retune.
Old 10-20-07, 10:06 AM
SC30096
SC30096's Avatar
Thanks for all help, I believe thats all the info I need. I think Im gonna get a full exhaust before I get this thing dyno tuned, cheers guys
Old 10-21-07, 11:16 AM
ConSynX
ConSynX's Avatar
Default re:
*sigh*
i'm not gonna try to back anything i said on a this forum...
but that guy is a pro-tuner, so u can go off him.
sounds like a WOT tune more than a tune for a daily driver, but w/e.
i used sources like the book, rx7 forums, mr2oc, supraforums and their vendors, and other 1jz companies that were willing to help get #'s from the gt4067'd 1jz.
Rphilip
08-09-11 11:03 AM
SC30096
06-03-08 04:23 PM
VW_Vanagon
12-15-07 12:17 AM
Hermosa
05-14-02 09:44 AM
Quick Reply: SAFC WOT vs regular driving
