1jz swap - what radiator are you using?
Old 10-22-07, 10:30 AM
ProjectLex
ProjectLex's Avatar
Default 1jz swap - what radiator are you using?
The radiator is one of the last things I need to buy before the swap is done.
There is good info here
http://intellexual.net/turbosc.html
But most of those have high end after market radiators. That is all good, I plan on going that route, but not yet. What OEM radiator would work? Would a stock SC radiator work with the 1jz or would a 1jz radiator work with the SC?
I am close to buying a stock 2jzgte rad, but am not sure that will work for this.
Basically what is the cheapest OEM radiator I can throw in there for now to get the car street ready? I just want it running so I can finish the interior and body work during the winter. I can upgrade engine components in the spring. The car is not going to be driven much until then anyway.
Going cheap........temporarily
Old 10-22-07, 12:29 PM
CCC-TT
CCC-TT's Avatar
stock sc300 radiator here, it works perfectly, and all the hoses match up
Old 10-22-07, 12:46 PM
ProjectLex
ProjectLex's Avatar
Thanks a lot man! Good to hear from someone who is actually using the stock sc radiator with the 1j.
Old 10-22-07, 01:34 PM
CCC-TT
CCC-TT's Avatar
ya i dont have any problems with it, mine is a little old so i might replace it soon but it works just fine
Old 10-22-07, 01:49 PM
ProjectLex
ProjectLex's Avatar
Yeah, I'll upgrade a lot of this in the spring; intercooler, maybe custom downpipe, exhaust, radiator etc. But for now I just want it done!
"1j is in!!! but has a few kinks to work out unfortunately"
What kinks you got? We're in the final stages and I figure we'll hit a few snags before all is said and done.
Old 10-22-07, 02:15 PM
1JZ300
1JZ300's Avatar
modine........
Old 10-22-07, 03:14 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Old 10-22-07, 03:58 PM
shern
shern's Avatar
I'm running the stock radiator with mine.
Massive lead foot in 115 degree Arizona without a bump in temperature. Highly recommended!
Old 10-22-07, 04:28 PM
ProjectLex
ProjectLex's Avatar
Thanks for the replies. If the stock rad holds up under those conditions in AZ, I'm convinced.
Sorry OLT - I thought about it as soon as I hit the post button.
My bad
Old 10-24-07, 07:43 AM
1JZ300
1JZ300's Avatar
your sig says your 1J is in progress, hows that comin?
Old 10-24-07, 08:06 AM
plex
1UZFE/2JZGTE
plex's Avatar
I'm on the stock radiator with no issues but will be upgrading to an aftermarket mkiv 6sp radiator.
Old 10-24-07, 01:36 PM
CCC-TT
CCC-TT's Avatar
well, i'm sure youve seen both threads about my car and the swap, basically not being able to rev over 4k is the main one
Old 10-24-07, 03:30 PM
sc250tt
sc250tt's Avatar
original soarer radiator here ,i got the hookups on jdm parts all day but but its still costly
Old 10-24-07, 03:59 PM
rykwebb
rykwebb's Avatar
I should have upgraded but the stock works great. I have two 12" electric fans ready to get mounted on it...just waiting on the scholarship check.... People who go with the new radiator like 1JZ300's, usually take it to the next level and get a new radiator hose, I know Greddy makes one. So, I would definitely feel comfortable going stock in your position.
masiah23
08-13-12 12:44 PM
SCSleeper
08-15-09 08:17 PM
ProjectLex
03-13-09 02:22 PM
ProjectLex
SC400 / 300 Classifieds
03-12-09 10:06 AM
JJG2005
07-22-06 09:51 AM
Quick Reply: 1jz swap - what radiator are you using?
