1JZ - Cannot Rev Pass 3000 RPMS - Need Guru.
#96
well i now i am certain its something to do with the STA and IGSW switches, CCC-TT just tell which pin you d/c on the white body plug is it the black wire with orange stripe.
Help is appreciated, I have wiring diagrams so I am trying to find out which pin you d/c so I can find it on the 92 sc
#97
Bobby, I am happy for you. You have worked so diligently, and the hardships you have gone through have to make spinning that motor to 7k rpm that much sweeter.
Now, you can start taking your time and wisely investing the money you save to make that motor scream. It has to be very confidence inspiring to have a motor under your hood very capable of making 500whp with the right modifications...none of which include a bottom end rebuild.
#98
#99
Hi All
I'm having same problem on my 1jz from Mark II to my Skyline r32. Can someone describe more details which `black wire' from ecu to cut-off.
#102
https://www.clublexus.com/forums/sho...d.php?t=325112
Look here about 3/4 down on the first post. There's a wire to cut.
#103
he doesn't even really have to TRACE the wire, if he has his service manuals as well, he can do what you were going to do, and just say where it goes on both ends, and we'll just track it down in our books. . .
PLEASE![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
i believe this is causing a problem for my power fc, but not my oem ecu for some reason
PLEASE
#105
PLEASE
oh wait is yours manual Consynx ?
